Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
WEGA KF50WE610 50 no red color
We were told its a optics problem that would cost abt $1000 to fix. Is that possible?
  • Anonymous Oct 18, 2008
    WEGA KF50WE610 no red color problem; no color red but things that are supossed to be red look dark purple - looks like I have the same problem than hundreds of other people with the same Sony model.
    No more purchasing of Sony products!
    Genius:
  • 1,139 Answers
Hello ml707,
This could be a problem with the red video driver circuitry or the signal processor. The $1000.00 price range is rather steep, I say this because you can buy one of these sets for $1400.00 used from:
http://www.amazon.com/gp/offer-listing/B0000E3DQE/ref=dp_olp_2/104-4293379-3459139
It is possible (the $1000.00 repair price) depending on if the lens is at fault along with other factors, Take into mind this is an LCD projection TV and the lens in this case is to focus the picture from the LCD screen onto the projection screen
I hope this helps,
Posted on Nov 15, 2007
  • Henry McKelvey
    Henry McKelvey Nov 15, 2007
    By the way. There is a possibility that this unit is a RGB LCD projector whereas the white light beam is filtered into three wavelengths (Red, Green, Blue) and then sent through three different LCD screens which are set to allow for RED GREEN and BLUE (via filters). This is configuration is also used and this would account for a higher cost for repair. So in answer to your question $1000.00 is withing the realm of possibility, however I would suggest that you take the set to other shops to see if you can get a better estimate.
Blue spots on Sony WEGA KDF60XS955
Thats caused by a bad optical block. The cost of that repair will almost always be greater than replacing the TV.Thats a very common issue with alot of Sony DLP models which suffered that optical block issue with the blobs of color usually blue or green
Dec 10, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
I have a sony grand wega kf-60we610, at first i lost the red color now the image is black and white
Not likely to be a do it yourself repair----Optical engine possible or main video board----suggest you get a technician to look at it.
Oct 30, 2012 | Sony Grand WEGA KF60WE610 60" Rear...
Hello i have wega kdf50we655. my problem is a yellow looking stain in the on the left side of the srceen,and also blue dots.i have been told that it is the optical block and will cost $500.-to $700. to fix...
Hi,yes definetely it will be an issue with the optical block .I am very sorry to say but the price it will be the correct one,usually to fix this problem it will cost you around $500 try looking for the part in partstore.com shopjimmy.com or amazon.com.
Feb 10, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Can you tell me what replacing the blue optical block should cost on a Sony Wega KDF-60WF655?
the optic block is not a specific color it has all the colors the part if bought refurbished is about 350.00 then the labor about 175.00 of course they always charge more for the part then you can get it for I would say here between 600.00 and 700.00
Jan 25, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have the same problem as the blue haze on the screen. Can a color block be bought and will it cost more than the TV is worth.
The optical block or light engine can be bought from encompass.com for $692.39 but there is a $1000 dud fee.
Dec 01, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand Wega KDF-50E2000 with a red stripe on top of Picture
There are some adjustments that can be made to align the picture. This might correct your problem. They should only be made by trained serv tech. If that won't fix it then replace the light engine. There are 2 different ones for this model. They are serial number sensitive.
Oct 30, 2009 | Televison & Video
Color problem with Sony Grand WEGA 42WE655
Well, there probably isn't any relation between the two problems occuring exept for the timing. Magnetism won't affect a rear projection LCD.
I would say that your description is a bit odd, though. Usually on this model, there is a blue blob that shows up, eventually turning into a blue haze, and a star pattern of stuck pixels. It almost sounds like you have a bad set of component cables. On the SXRD's, they usually turn green.
Does it do it on all inputs (including the channels)? If it does, then it is the optical block. If it does not, then I would suspect that it is cable-related. If it is the optical block, then there is no way that any input can be different from the others (except for digital/analog differences, but those are usually obvious with patterns vertically on the screen).
If it does not look the same on all inputs or channels, change out whatever cables you are using. A loss of the red or blue cable in a component can give the symptoms you describe.
I hope this helps you...
Jan 08, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Colour splashes on screen.
the lcd panels in the optics block are going bad, getting dirty etc., the block needs replacing and will cost upwards of $750.00 total.
google sony optics for your model for warranty extension possibilities.
Jan 04, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Red color is missing - everything is green
You will need the optical block replaced. Approximately $1000 or so plus around $400 labor and taxes. Visit Sony's website to see if they are still honoring the extended warranty for the optical block issue. They know it as a green tint complaint. The menus will also be affected if you have the problem.
If the issue is no longer covered, try negotiating a shared cost repair.
Nov 01, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
62 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
