Question about Sharp Viewcam VL-Z3U Mini DV Digital Camcorder
What doe DEW mean? The "DEW" sign keeps coming on and then shutting off..
  • 405 Answers
DEW sign indicates high humidity level inside the camcorder. What you experiencing has nothing to do with humidity, It is a faulty connector on a junction board. Sharp has fix for it.
Posted on Oct 28, 2009
    Scholar:
  • 116 Answers
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
Posted on Sep 22, 2009
My digital camera wont work and it keep saying DEW. what does that mean? it is a sharp vl-z5 digital camera
I HAVE A VIEWCAM VL-Z7, I STARTED TO CHARGE MY BATERRY TO THIS JUNKY UNIVERSAL CHARGER AND FOR SOME REASON IT TURNED ON BUT 1 MINUTE LATER IT TURNED OFF AND NEVER TURNED ON AGAIN
Dec 11, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Bypassing dew sensor on a Sharp VL-Z7 mini DV
- the solder joints to the DEW Sensor were "cold joints" which means that the solder joint is defective - is not a sound joint. This means that with temperature variation, the solder joint can intermittently separate and break the circuit, causing the DEW Indicator to come on and completely shut down the camera. The first problem I had with the camera was on a cold day, so it seemed to make sense.
Here is a picture from the perspective of the tape cover being at the top of the picture and the rest of the camera at the bottom. The dew sensor will be on your left.
go to:
http://omlets.tripod.com/sharpdew.jpg
Then, get a real slim soldering iron with a fine point. Open the tape cover and take the tape out. Get a strong light to shine down into the mechanism.
If your camera is like mine was, you may see a brownish material on or around the solder joint - this is flux used in soldering which was applied too heavily, and not heated long enough to burn off. The joint therefore doesn't quite connect the dew sensor to the terminal post - depending upon heat/cold ambient conditions, sometimes it makes contact and sometimes it doesn't .
Heat up the soldering iron - make certain the point is tinned (has a thin film of solder on it). Carefully just touch each solder joint for a couple of seconds - just enough for it to melt, and then quickly remove the soldering iron. You don't want to leave the iron in contact with the solder too long or it may melt other insulation around the terminal. This all probably sounds more complicated than it really is - but it really is just a 5 minute operation. If you've not done much soldering, and feel uncomfortable about trying it, you may want to take it to a radio, tv or computer repair shop and ask them to do it for you.
Jan 25, 2009 | Sharp Viewcam VL-Z7U Mini DV Digital...
Sharp VL-Z900
The solder joints to the DEW Sensor were "cold joints" which means that the solder joint is defective - is not a sound joint. This means that with temperature variation, the solder joint can intermittently separate and break the circuit, causing the DEW Indicator to come on and completely shut down the camera. Here is a picture from the perspective of the tape cover being at the top of the picture and the rest of the camera at the bottom. The dew sensor will be on your left.
go to:
Jan 15, 2009 | Sharp VL-Z5 Mini DV Digital Camcorder
Shut down "dew"
This happens when you take camera from cold(er) environment to warmer environment, dew forms on the recording head, so as a precaution the unit locks up. The solutions is to leave the unit switched on and wait till the dew incator goes out( can take up to an hour) I found this out when on holiday, i would go from an air conditioned room to bright sunshine and it happened all the time.
Sep 28, 2008 | JVC Everio GZ-MG30 Camcorder
Sharp vl-z8 dew light keeps coming on
It seems that the due detector can suffer from bad soldering or soldering alteration after few months of use.
1. The (ideal but uneasy) solution consist to fix this solder by making a clean new one, I personally did it, and it worked for a few months without a problem anymore ; but then it came back again.
2. The other solution consist in short-circuiting the dew detector to eradicate the problem.
Of course, it will also mean that when real dew will happen you may use the video tape recorder when you shouldn't, but at least you should not see the problem coming back again some months later.
To know more about this dew detector circuit and how to fix it the way you want go there:
http://ataplow.googlepages.com/sharp-dew-problem
a zoomed picture of where to fix the detector can be found here:
http://ataplow.googlepages.com/sharpdew.jpg
Hope this will help as it helped me,
Good luck,
Fabien.
Sep 25, 2008 | Sharp VL-Z800U Mini DV Digital Camcorder
Warning Dew Detected
Where are you keeping that camera? I would return this camera if it keeps happening (before warranty expire).
May 14, 2008 | Panasonic Proline AG-DVC7 Mini DV Digital...
DEW indicator / battery
In your owners manual on page 52 you will find a list of authorized service centers. Give the one in your area a call. Give them the brand name and model number of the camcorder. Tell them you are having a problem with the dew warning coming on while using the camera with the battery. They should be able to help find a answer to this problem.You can also call the panasonic customer support telephone number at 1-800-211-7262 between the hours of 9am-7pm EST. Give them the brand name and model number of the camcorder and ask them for help with the problem of dew indicator coming on while in use with the battery. I hope this information helps you with your camcorder problem.
Nov 20, 2007 | Quasar VM-L450 Camcorder
Dew
PUT A JUMPIN A SENSOR DEW SMALL CIRCUITY IN MECHANISM OR PUT A HAIR DRY HOT IN IN MECHANISM BY 5 MIN. OR 10 DNOT TO PUT STRAIT DRY TURNG ON CAMERA AFTER THIS TURNG OFF AND TURNG ON AGAIN A GOOD LOCK
Sep 28, 2007 | Sharp Viewcam VL-Z3U Mini DV Digital...
Dew liht comes on and camcorder shuts off
I had the same problem with a VL-Z3U, there was no home fix, the dew sensor needed replacing costing $130 CAD
Jun 18, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
HELP, my panasonic keeps shutting off. Dew? condensation?
Put it in a very dry place, and let it sit for a few days. How is it getting either dew or condensation? Once dried out, keep it in an airtight plastic bag.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Sharp Viewcam VL-Z3U Mini DV Digital Camcorder Logo
535 people viewed this question
Top Sharp Video Cameras Experts
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
