Question about Kenmore 96213 Electric Kitchen Range
2 burners work, 2 don't
We have an electric range in which the 2 burners on the right will not work properly. They turn on initially and heat up, then turn off again within 10 seconds. Sometimes they will heat up again, but immediately turn off again. I know that electric stoves heat up and cool down in order to maintain a certain temperature - but this is not the case w/ these 2 burners. The 2 burners on the left work fine. I can not boil a pot of water on either burner on the right. Where would we begin...a short circuit? A thermometer? Thanks in advance!
  • Anonymous Jan 06, 2008
    one burner does not work
  • 975 Answers
Ok, first check that the ranges are seated properly , clean the connectors , do a test , if it still doing the same problem , then you need to replace the modules of each range thats not working,in this case 2 modules.
Posted on Apr 21, 2008
2 hobs on my electric cooker are not working
Fixing Electric Stove Burners that Don't Heat Up Properly ...
? 2:34
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
Electric Range Stove Repair: How To Repair Burner ...
? 6:52
Jan 31, 2012 - Uploaded by applianceassistant
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
Oven is not heating properly
Could you find the completer mode number because the number listed above your post is for a gas oven.
Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Thank You, Sea Breeze
Mar 25, 2009 | DCS RGS-484GG Gas Kitchen Range
Maytag Gemini Electric MER6770AAC
I originally posted this problem March 1, 2009 as Bodhi58 and recently had the problem fixed. It turned out the burner needed to be replaced as the wire was split in the burner. The part alone was $210 but the service charge.
Feb 28, 2009 | Maytag MER6772 Gemini Electric Kitchen...
One burner does not work. The outer burner works, but smaller inside one gets no power. It is only 2 years old
I called Maytag and even though my warranty had expired, they offered to fix it for free. What a nice thing to do!!
Oct 08, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. You pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. You removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. You put the replacement burner in the back burner of the same size and had heat within 10 seconds. You changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Sep 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Need advice on Kenmore electric range
turning frot burner on sparked and now all 4 burners don't work any more
Jan 03, 2008 | Kitchen Ranges
Single Burner Doesn't Heat Properly
1. Turn off power. 2. Determine type of burner. If it's a plug-in, test faulty burner in another receptacle * If it works, replace the original receptacle * If it doesn't work, replace the burner. * Replace other faulty components If it's a flip-up burner: * Disassemble and replace the faulty burner and any other faulty parts. 3. Restore power. 4. Test. *If it still doesn't work, call a repairperson.
Jan 18, 2006 | Crosley CE35100AA Electric Kitchen Range
Kenmore 96213 Electric Kitchen Range Logo
235 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
