My Cannon MG5520 says not connected to the computer but has been for over a year. I reconnected to the network via wps but it still says not connected to the computer.
These extracts from the user guide should solve your problem:
To connect network through Set Expert
HOME ? Settings ? NETWORK ? Network Connection
Used in special circumstances such as in offices (For example, when a static IP is needed).
1 Select a network connection either through Wired or Wireless.
2 When connecting via Wi-Fi, use the one of the following network connection methods.
AP List Connects the network by selecting a network from the AP
(Access Point) List.
Enter the SSID Connects by typing in the name of wireless AP.
WPS-PBC Connects easily by pressing the button of the wireless AP supporting PBC.
WPS-PIN Connects easily by typing in the PIN on the web site of the desired wireless AP.
Ad-hoc Connects directly to via a wireless-enabled PC or mobile
phone.
Usually you select the wifi network, tap Connect and then you're prompted for the password. I've never tried it, but if you pressed WPS on the router just before tapping Connect, maybe WPS would work.
Did you change the password on the router? Did you WPS to connect the phone to the router? If so, use WPS again.. that's where you press the WPS button on the router and tell the phone to connect via WPS at about the same time.
The passphrase is the password your router needs to connect the printer to the router. If your printer has a WPS connection ability, you can push the WPS button on your router and it should complete the connection without the need for any input from you.
It relies on the WPS button on your router. Get to the Searching for WiFi on the printer then push WPS button on router. After a little delay the printer should say it has connected to network. If not, use the function that connects via the router password entered directly.
Good luck and please rate 4 stars if answer is helpful.
Open the settings menu on the printer. For the network settings enter the connection parameters. If the printer has WPS you can skip the settings and use WPS to connect.
CALL YOUR ISP FIRST. wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections. Some of NETGEAR's products use the name Push 'n' Connect for WPS. To use WPS, your product must support WPS and be compatible with WPA security. WPS can automatically set up a random network name (SSID) and strong WPA wireless security for wireless routers, access points, computers, adapters, Wi-Fi phones, and other electronic devices. WPS lets you use a push button or enter a personal identification number (PIN) instead of manually entering a network name (SSID) and password:
Push button. The WPS button is either on the product or a clickable button on a wizard or utility screen.
