Viking 24 in. Professional Series VUD040 Stainless Steel  Built-in Dishwasher
Problem for Viking 24 in. Professional Series VUD040 Stainless Steel...
Viking Dishwasher leaves a film on the dishes
By Ron4478 on Nov 15, 2007
My wife tells me the dishwasher leaves a white residue on glasses and table ware. She has reduced the soap (cascade liquid) to one teaspoon per load and still the problem continues. She ends up hand washing everything after running a load. The file does come off when hand washed. I turned up the water temp but that did not help..
Comments:
Sep 30, 2008
- Back in Nov of 07 I started this issue. I subsiquently had my water tested. I discovered the water here in Riverside, Ca is over 11 parts per million (VERY, VERY, hard). As a result, I was told to fill the soap contianor to MAX and "add vinegar" to the jet dry container 50%. Now I have no more white film and the dishes come out very clean.
Sep 30, 2008
- I was told by my local applance shop that our water is very, very hard (11 ppm). He said to use max amount of detergent and 50-50 vineger in the jet dry dispenser. Since doing that, no further problems.
Same Problem
Jul 16, 2008
-   sandy build-up in glasses and on plates-   Guest
Jul 08, 2008
-   I outfitted my entire kitchen in Viking...a cooktop, double oven, microwave, wine cooler, refrigerator and yes...that damn dishwasher! It is horrible. It is a shame that Viking even puts their name on it. I had someone out to fix it three times and it is still not working well. I can't believe that I have had it for only 2 years and I am going to end up replacing it.-   Guest
Apr 08, 2008
-   We have the exact same white film on everything.  It  doesn't rinse off, either.  And you can taste it.  I haven't found a solution.  Wondering if it's worth the cost of repair or if it's time for a new machine.  We've had this one for 5 years. The problem started about 4 1/2 years into it.-   Guest
Mar 29, 2008
-   We had the dishwasher with NO Residue for almost 2 years. Then out of nowhere--or as if suddenly out of warranty the FRIGHTENING FILM appeared. It is unwashable, impervious to self-scrubbing, as if an alien coating from another PLANET! I had long heard that Viking makes a shitty dishwasher--and now I'm CONVINCED! Resolution: Buy WHIRLPOOL. (P.S. And we wonder why or where from we get CANCER!)-   sicktodeath
Feb 03, 2008
-   I have a Whirlpool Gold Quiet Partner dishwasher that's 6 yrs. old. I have very hard water and no watersoftener. For
the past 2 months, my dishes have a film on them. I soaked my glasses and silverware in vinegar. It helped but the film came back. I keep the rinseaid holder full and don't know what else to do. I use Palmolive liquid dishwasher detergent. I ran vinegar through the dishwasher to see if that would help and it didn't. Help!-   Guest
Best Solution
posted on Sep 30, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I've been reading up on this because my dishwasher has done the same thing. I'm not so sure it's the actual machine, but the kind of water that is used in your city. I have read that the water temp. should be between 120 & 145 and that you should put vinegar in the jet dry container. I'm going to try this with the highest of hopes because who wants to wash their dishes TWICE? :(
Solution #2
posted on Apr 02, 2009
Not Rated)
mambro
Rank: Wiz
Rating: 79%, 161 votes
there is a new product out called the dishwasher filtration system. it is specifically designed to solve these problems. it filters the hard water before it goes in the dishwasher. it is very affordable and you can get it at www.dishwasherfilter.com. you will love this product.
Was this helpful?
Yes
No
Solution #3
posted on Jan 20, 2009
Not Rated)
leeemac
Rank: Apprentice
Rating: 0%, 0 votes
I have had the same problem and have been very pleased with the results of a product called LemiShine. I haven't tried the vinegar in the jet dry container yet, but for those who have and it hasn't worked, try Lemi Shine. I found it at Target
Was this helpful?
Yes
No
Popular Solutions for Viking 24 in. Professional
Questions and Unsolved Problems for Viking 24 in. Professional
Do you recommend Viking 24 in. Professional Series VUD040 Stainless Steel (Premium) Built-in Dishwasher?
Answer
Answer
between cycles the dish washer does not empty all the way and upon refill it will overflow?
Answer
Viking Washer will not operate on normal setting - no water. Water does come on other settings.... (More)
Answer
Hi- I just bought a house with the Viking VUD040 dishwasher but the lettering is all worn off on the... (More)
Answer
Our Viking dish washer no longer works. It sounds like it is in the drain cycle and the control knob... (More)
Answer
some water remains in bottom of dishwasher after cycle is complete
7 Other Users Have The Same Problem - Continued
Comment by onsi, posted on Dec 23, 2007
I am having the same problem after 6 years problem free use with my dishwasher. It has the correct amount of soap, jet dry... water supply has not changed. Film does not come off even after hand washing.
Comment by Guest, posted on Dec 18, 2007
This happens to us, also, if there isn't enough salt in the water softener or if the rinse agent runs out. Ours is a Whirlpool Gold Quiet Partner IV.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwashers Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
