2003 Saturn L-Series L300 Logo
Posted on Aug 05, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the fuse/s for the map lights and dome lights
Steve Earl
Level 3:
Master:
  • Master 269 Answers
  • Posted on Aug 05, 2015
Steve Earl
Master
Level 3:
Master:
Answers
269
Questions
0
Helped
79831
Points
1290
ANSWER by patrick mannion on June 01, 2010
Looking at a wiring diagram the dome light and rear reading lights operate through the body control module. Check the BCM 2 fuse, BCM 1 fuse and BCM cluster fuse they may all be in the circuit. These fuses are in the engine compartment fuse box.
Dome glove box trunk vanity map lights all out 2003 Saturn L300
I changed the entire dome light fixture due to weak tabs that hold the center light.. now the dome lights work,the map lights do not work.there a fuse or something that controls the map lights? ?
Absolutely! There's a fuse that controls every light on your truck. Some share the same circuit, some don't. Consult your manual. If you don't have one, get one - you will need it repeatedly.
Which fuse controls the map lights in the 2002 jeep liberty
map light? and no symptoms..
the dimmers on the HL stalk. (held lamp , park dash dimmer)
if the power to the map is dead so will many other things be dead.
lost the 2002 operators guide, ?
in cars 1 fuse runs many things. thus my others dead comment.
why not be clear, , the overhead dome map light. say where
hand is, because many cars have dash map lamps, so.....
my hand is on the DOME light above and its what DEAD?
i log into alldata.com so can you.
i look at this schematic, and there are 2 lamps
MAP and cargo, map is the traditional DOME. lamp now MAP.
but they both use the same fuse. so are both dead.?front and rear?
or both stuck on? what are the symptoms.?
both lamps have manual direct control (sw) PUSH THEM ?
If not in manual mode, there are controlled by the BODY computer BCM..
both run off JB1, fuse 34.
now i bet the next question is where is fuse 34, well its in the JB.
and where is JB its at your left knee, (USA only LHD only. comments )
fuse 34 runs the foot courtesy lamps... are they dead?
and visor vanity.
there are 2 fuse boxes. one in engine bay and one in cab, some cars
3.
JB =means cab
PDC fuse box is engine bay, Jeep lingo...
JB is in plain view above left ankle, look down then up and left.
bingo JB.
the box had fuse and relay ID's
the operators guide shows , all the fuses and name.
i dont have the OP guide so cant find the name for Fuse 34.
but there is no need yet if the other lamps work then FUSE 34 is good.
and is 15amps.
2006 nissian frontier se no interior lights
hAVE YOU CHECKED THE FUSE FOR THE INTEROR LIGHTS?
2005 f150 front dome and map lights won't come on
Some of the Dome lights have a 3 position switch. Completely off, completely on, and working when doors open.
Trunk cargo light not working after LED installed....
The SJB supplies power to the interior lighting system. The SJB will set DTCs if certain circuit failures exist with the interior lighting system.
Visual Inspection Chart Mechanical Electrical
  • Courtesy lamps
  • Map lamps
  • Luggage compartment lamp
  • Vanity lamps
  • Glove compartment lamp
  • Smart junction box (SJB) fuse 3 (15A)
  • Circuitry
  • Courtesy lamps
  • Map lamps
  • Vanity lamps
  • SJB
Check fuse # 3 SJB
95 f150 inside ligths stad on tok + cable off battery took fuse out to cut the ligths next day the over drive ligth starter flashing HELP
Im not sure if this is going to be your problem but on f150s 250s 350s rangers and explorers, have very weak door switches that are used to tell the dome light to go out, when it fails the dome light does not go out if you have left the fuse out for the dome light there will be other problems, on most models the fuse that the dome light is on also controls the odometer, windsheild wipers and the electronic shift for the overdrive, generally a quick fix for the problem is to remove the bulb for the dome lamp, and insure the fuse is in properly, if you have map lamps in your vehicle these should still work, the only issue is you will not have a dome lamp when you open the doors only the map lamps youll have to turn on manually, If this does not fix the error with the overdrive most likely have shorted door switches throwing the circuit for a loop
Fuses for dome lights 2001 Hyndai Elantra
b-alarm 10a fuse located in engine compartment fuse box,fuse gives power to dome and map lights.
2helpful
2answers
Just bought an 03' f150. my map lights inside work, but the dome and cargo bed lights do not. also cant find a diagram of the fuse panel anywhere. Thank You
have u check the bulbs?.... i would try to see if they ok remove em an check for power going to those locations, activate ur switches an see if you get any power may just be burned bulbs..... if the fuses seem to be OK
2006 Mustang dome/map lights won't turn on
Is the climate control out also? If so it is fuse 10 (5amp) interior fuse panel.
Top Saturn Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Saturn Expert? Answer questions, earn points and help others
