Question about Marantz Audio Players & Recorders
I have my cable box connected via HDMI to my SR-5002. From the SR-5002 I am connected to a new Samsung Series 4 (430) HDTV using HDMI cable. I get sound from the receiver when the TV is off, but no sound when I turn on the TV. The picture is fine.
  • 2 more comments
  • timothy_mill Jul 12, 2009
    not sure I understand. Do I need to connect additional audio cable from my cable box to the receiver or from the receiver to the TV?
    You need an audio cable from the tv to the receiver for the audio from the tv in order to get this setup to work.
    Can I use component cables?
    From the TV's audio out, connect to the receiver's audio in. Do I need to run separate audio cables from the cable box into the receiver. To watch TV, my receiver is set to DSS-HDMI...does this need to change.
    Thx
    must be doing something wrong...
    I have left my HDMI connected (by the way the Marantz is HMDI 1.1 and TV rated from 1.3 or newer)
    From the TV's audio out, connect to the receiver's audio in??? I guess I am not sure where to connect to on the Marantz
    You nailed it...thanks, now I can relax
  • 2,200 Answers
Hi
From reading your post you have the connections around the wrong way. If I am understanding you correctly this is your connection.
cable box - stereo amp - TV
Your connection should be
cable box - TV - stereo amp
You will first need to connect your cable box to TV via HDMI - then use RCA out on your TV to send sound to your amp (RCA in). If your TV has another method of audio out compatible with your amps audio in connections you can use this also e.g HDMI.
Hope this helps. If so - please remember to accept and rate my answer. Many Thanks.
Posted on Jul 12, 2009
  • 3,037 Answers
Benjamin
  • Benjamin Patri
    Benjamin Patri Jul 12, 2009
    yes you can
    to run separate audio cables from the cable box into the receiver. No you do not
    To
    Depends on what input you are using. it is probably fine
    Thx no problem
    Top Expert:
  • Marantz Master
  • 83,850 Answers
DO U HAVE THE OUTPUT OF THE AUDIO HOOKED TO THE VARIABLE AUDIO OUTPUT FROM TV? THAT IS THE WORK AROUND FOR THIS
HDMI&DVI ports already used on LG HDTV.I have X BOX 360 S,has a HDMI plug, can I use a HDMI splitter to plug in the X BOX in the DVI port ?receiving computer via HDMI now
You will not be able to split them, but they do make a HDMI Switcher, allowing you to use your Xbox 360 as number one and your PC as number 2, w you cannot mix both at the same time.
May 02, 2016 | LG Televison & Video
When selecting the source, HDMI 2 will not highlight, Only TV. HDMI cable connected to box and to HDMI2 port on TV
You have to check the HDMI cable. In Samsung tvs the HDMI sources only highlights if the a proper HDMI sources is connected to the corresponding HDMI port of the tv. Also check by connecting any other device which have and HDMI connectivity to the HDMI 2 port.
www.electro-medical.blogspot.com
https://www.facebook.com/electromedservices?fref=nf
Oct 02, 2015 | Samsung UN22F5000AF 22 LED 5000 Series TV...
How can I connect my Imac with my Toshiba hdtv Series V4210U via airport extreme?
Does your Toshiba have a wireless adapter? If so, you can set up a home network, if you don't already have one. If no,Does the iMac have a VGA or HDMI connector? You can connect via a adapter cable, Vga to HDMI or a HDMI cable, depending on the iMac connections.
Jan 26, 2013 | Computers & Internet
How to hook up a cable remote to a Samsung cable box?
    • 1 Examine the back of the your cable box and the back of your Samsung HDTV. Note which cable jacks are of an identical size and color. Those are the ones that can be used to connect the two devices. Samsung HDTVs cluster all the jacks in a single panel near the power cord.
    • 2 Look at the square rectangular boxes labeled "HDMI In." These are for high-definition multimedia interface cables--combination A/V cables that provide the highest possible image and sound clarity. Look at the back of your cable box for an identical jack labeled "HDMI Out." If you see one, connect the two jacks using an HDMI cable. If you don't, you need to use another set of cables to hook up your cable box.
    • Sponsored Links
    • 3 Check for a series of three round jacks labeled "Component In" and color coded in red, green and blue. These are component video jacks, which provide a good HD picture, but not as good as HDMI. If your cable box has an identical set of "Out" jacks, use them to connect the two components.
    • 4 Look for a pair of red and white jacks (possibly connected to a yellow one). These are audio RCA jacks. If you're using component video cables to hook up your cable box, you will need to hook these two up as well: Component video cables don't provide sound. Any cable box that uses component video cables should also have "Out" jacks for RCA audio cables.
    • 5 Find the raised circular jack with a pinhole in the center of a milky white plastic interior. This is the coaxial jack. Samsung HDTVs label them "Ant In." Every cable box should have a corresponding jack labeled "Out" or "Ant Out." If none of the other cable jacks on the cable box match, use a length of coaxial cable to connect the TV to the cable box through these two jacks. You can also use this connection to hook the TV directly to the wall cable.
    • 6 Turn on your TV and cable box, and set the TV to the input jack connected to the cable box. You can do this by pushing the Menu button on the remote, scrolling down to the "Input" option and pushing "Enter." That will let you cycle through the various input options, labeled by cable type (HDMI, component video). Press "Enter" again when you reach the right component, then exit the menu. You should now be able to watch TV as normal.
Read more: How to Hook Up a Cable Box to a Samsung HDTV ' eHow.com http://www.ehow.com/how_4867255_hook-cable-box-samsung-hdtv.html#ixzz2DwgQRtRE
Dec 03, 2012 | Televison & Video
CAN'T FIGURE OUT HOW TO WIRE MY SAMSUNG HDTV TO A HD CABLE BOX
On the back of your Samsung HDTV there is a HDMI input and on the back panel of your cable box there is a HDMI output.
Connect the cable box and the HDTV using a HDMI cable .
Hope this helps.
Oct 11, 2010 | Samsung Televison & Video
Digital Audio cutting out
I have the same problem with my RX-V565 receiver. Did you get this fixed?
Albert
Oct 08, 2009 | Sony Playstation 3 (PS3) Console
Samsung hl61750a - unable to display video service over hdmi
I was using an hdmi cable purchased online. A friend told me that it might be the 'cheap' hdmi cable. I tried a set of Monster hdmi cables and problem solved. So all hdmi cables are not the same.
Jan 29, 2009 | Samsung HLN5065W 50" Rear Projection...
I have the following hardware: Marantz SR-4003 Receiver, Samsung LN52A650 HD TV, Samsung BDP-1500 Blu-Ray player, Scientific Atlanta Explorer 8300HD cable box, two Paradigm Millenia 20 LCR Bookshelf...
Remove the HDMI cable (out) to the speakers from the receiver.
Connect regular speaker wire from the receiver to the speakers.
Of course, remove the (now extra) HDMI cable from the tv.
That will remove the loop.
Jan 25, 2009 | Marantz SR-5600 Receiver
Samsung HL 61A750A1F
The Samsung Television has 3 HDMI inputs, You would connect an HDMI cable from the Cable box to your television and go into a menu on the television to select the appropriate HDMI input.
New cable boxes should have the HDMI connection.
Most Flat screen televisions I've seen have an input button on the television itself. Pushing it should allow you to switch between inputs.
Sep 04, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
131 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
