Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Water buildup in the fridge, dripping in from the freezer
Whirlpool Gold
Model EK4226828
I have the freezer on top, no ice maker.
With this fridge, there are two openings from the fridge into the freezer.
The slide tray in the freezer is removed to see layers of ice have formed.
Drain hole in the rear of the freezer is frozen over?
The only fix I have is to unload/unplug the fridge, defrost and start all over again.
HELP!
    Champion:
  • 287 Answers
This could be a bad thermostat. If your thermostat never closes it's swith then the defrost element never comes on and you get the problem you are having. Easy fix. Do you know where your timer is and can you retate it?
Posted on Jul 16, 2009
Leaking water
Did you inspect if the hole in the drain inside the fridge at the bottom is not blocked? Try to clean it with a swab. Sometimes this causes a "leakage" of condensed water.
Dec 14, 2013 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a 3 door Whirlpool Gold fridge. The bottom
ACTUALL FREEZER TEMPATURE MAY BE ABOVE 17 DEGREES. THEN THE ICE MAKER WILL NOT WORK. OR MOISTURE GOT IN TO THE HEAD OF THE ICE MAKER AND FROZE THE GEAR.
Apr 24, 2010 | Refrigerators
Ice Maker on Whirlpool Side by Sidek stopped making ice
Go to sears.com, select "Parts Direct", enter model number and wait for unit to be displayed, find ice maker part number and price.
Oct 01, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Smelly Ice and water leaking into top shelf
Does water in door dispenser taste bad? If not, Try arm and hammer fridge deoderizer. It will help to absorb fridge odors which may be clinging to water molecules in ice maker tray. Ice maker tray is open to freezer area.Water is very medium to infiltrate with odors. Try this first
Jul 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Black spots on ice
The ice maker mold is deteriorating. Replace the ice maker.
Jul 11, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Whirlpool gold ice maker
The inlet tube is hitting the ice shield and missing the opening.Remove the ice maker just enough to align the tube into the hole in the shield.
May 13, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
290 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
