Question about Nvidia Microsystems GeForce 8400 GS,, PCI Express Video Card
I have a galaxy microwave. I was boiling egg and coz of over heat it blew open the door. The door hook that holds is broken, is there a solution to this where I can replace the hook.
    Sergeant:
  • 400 Answers
DOOR LATCH PROBLEM...HOLDING IT CLOSED AND TURNING IT ON WORKS AND HEATS. IS IT A DIY FIX PROBLEM? THANKS FOR THE HELP, DEBBIE
follow this steps and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#11#ixzz2gPqmd5pf
Sep 30, 2013 | Frigidaire FGMV174K Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
I boiled a egg in my microwave multiwave oven 750 watt and after 3 min the egg blasted and the oven stopped working. what could have happen and how can we fix it at home?
Unfortunately this is one of the worst things that can go into the microwave, when it blasted it covered everything on the inside including the magnetron and door switches. The cost will be high because chances are high the magnetron is damaged and the interior cavity is covered in egg not to mention the door latches, I would recommend replacing the whole unit.
Mar 30, 2012 | Microwave Ovens
My microwave turns on with the door open?
Check the door switches and mounts. See this help file.
Dec 17, 2011 | Sharp Microwave Ovens
I blew up an egg inside the microwave, and it blew the door open. Now the door wont latch. It looks like the plastic latches are stuck, is there an easy way to fix this?
What brand and model is microwave.
Also how is the situation of door, can you close it and if yes you can work the oven or else?
Aug 19, 2011 | Kitchen Ranges
Boiled and egg and killed the microwave. Any way to revive it?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ii
Apr 03, 2010 | Sharp R-320HQ Microwave Oven
Microwave blew up after cooking an egg
Yes the internal fuse will have blown. I would also think the door latch switches and monitor switch will also need re adjustment
Jul 08, 2007 | Sharp R-408J Microwave Oven
Nvidia Microsystems GeForce 8400 GS,,  PCI Express Video Card Logo
48 people viewed this question
Top Nvidia Computers & Internet Experts
Terry
Alun Cox
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
