Question about Plantronics Explorer 330 Headset
Need to reset plantronics explorer 330 because it might to connected to a phone i no longer have and im trying to connect it to a new phon. or, if there is an alternate solution to this problem, any advice would help. thanks!
  • 10 Answers
This is probably far too late now, but I'll post it for future reference. You first shut off your 330 then restart it, but continue holding it for around 8-10 seconds (usually it takes less than that) and the headset will start flashing blue and red.
You are now in Pairing mode a.k.a. reset mode. While it is flashing, tell your phone to start looking for Bluetooth devices and when it displays "3XX-Plantronics" (or something similar), you know you have the right thing.
Simply select that and enter the default factory code: 0000 and you now reset and paired the headset!
Posted on Mar 10, 2010
My plantronics savor m1100 bluetooth headset suddenly gives very bad static sound while making or receiving calls but a2dp is perfect sounding still. I want to know how to reset this m1100 bluetooth headset. and not the normal pairing unpairing etc etc.
Posted on Aug 24, 2011
My new blackberry pearl no reconnize my plantronic 330
Test the headset on another phone, if it doesn't work on the other phone then your headset is defective. Connecting the headset to the blackberry is fairly simple. Just verify that the Blackberry's bluetooth connection is active and make sure the headset's connection is active as well. Select the plantronics headset within the Blackberry's bluetooth menu, it should be listed in the menu if the headset is working.
Mar 05, 2011 | Plantronics Explorer 330 Headset
Plantronics 330 connects to phone but no volume on the headset/microphone
Remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove the battery for a few seconds, then replace the battery and turn it back on again. If this does not resolve the issue, delete the pairing information for your Explorer 330 headset and pair it with your phone again. The link below for the Plantronics Explorer 330 has the pairing information.
Plantronics Explorer 330 Pairing Information
Good luck from Headsets Direct!
Dec 31, 2010 | Plantronics Explorer 330 Headset
When I cmate the bluetooth to the cell phone (motorola Razor) I can not hear the caller. They can hear me but I have to listen from the phone to hear them. Did I connect wrong?
Remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove the battery for a few seconds, then replace the battery and turn it back on again. If this does not resolve the issue, delete any pairing information for your Explorer 330 headset and pair it again with your phone, carefully following the instructions on the link below for the Plantronics Explorer 330 User's Guide.
Jul 21, 2010 | Plantronics Explorer 330 Headset
Headset won't stay connected.
The headset may not be pairing up correctly due to the difference in bluetooth applications. If you have a new telephone with the headset already paired up to the very first phone, it will automatically go to phone number one or the phone that it was last used with. If the answer is not in the users guide, you can try Plantronics tech line 800-544-4660.
Plantronics Explorer User's Guide
May 12, 2010 | Plantronics Explorer 330 Headset
I am trying to pair my Plantronics Explorer 330 headset to my new phone, an HTC Eris. the phone does not recognize the device. Do you have any ideas?
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Dec 21, 2009 | Plantronics Explorer 330 Headset
I cannot connect my 330 bluetooth to my phone, and I also cannot
Once you make your cell phone discoverable, then put the Plantronics Explorer 330 into pairing mode by holding the call control button until the headset flashes red and blue. Here is the link below for the Explorer 320 user guide which has the pairing instructions, it will be the same for the 330.
Plantronics Explorer 320
Jan 10, 2009 | Plantronics Explorer 330 Headset
How do i listen to music on my plantronics bluetooth that is connect to my samsung blackjack
The Plantronics Explorer 330 doesn't have the A2DP technology (Advanced Audio Distribution Profile) for streaming music, you need to look for a headset that has the A2DP Bluetooth profile built in like the Plantronics Voyager Pro+ and the new Plantronics M50. The Plantronics M50 is a new model which is now available. For more information these two new models, please see the links below.
Plantronics M50
Aug 17, 2008 | Plantronics Explorer 330 Headset
Connecting bluetooth plantronics 330 headset to nokia cell phone
Here is a link to an Explorer 320 User's Guide, that will help you with your connecting to the phone. The instructions for pairing would be the same for the 320.
Plantronics Explorer 320 User's Guide
Aug 09, 2008 | Plantronics Explorer 330 Headset
Connect Plantronics Explorer 330 to Verizon Moto W755 Cellphone
See page 6 of the Explorer 330 user guide for the correct pairing instructions. Link included below.
Good luck from Headsets DIrect!
Aug 01, 2008 | Plantronics Explorer 330 Headset
Plantronics explorer 330
I just figured out how to reset the 3XXPlatronics 330. The guest might of of made it a little confusing for some:
1) TURN OFF bluetooth head set by holding the volume control button for about a few seconds until it flashes blue.
2) Make sure your phone's bluetooth is on and on discover mode.
3) Turn on the blue tooth head set (NOTE: HOLD DOWN THE VOLUME BUTTON UNTIL IT FLASHES BLUE AND RED)
4) Lastly, go into your search menu to find new bluetooth devices. The device should show up as "3XXPlantronics" (PASSKEY IS 0000).
P.S. Keep in mind this worked for me, but if it doesn't work feel free to email me at; cispy006@yahoo.com
Mar 15, 2008 | Plantronics Explorer 330 Headset
Plantronics Explorer  330 Headset Logo
1,376 people viewed this question
Top Plantronics Radio Communications Experts
skiffy99
skiffy99
Level 1 Expert
shaun taylor
gggg
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
