You vehicle has two fuse's ! one in the underhood fuse box EPS/STR WHLCNTRL an it is a 60 amp . An there is one in the BCM fuse center - EPS 2amp fuse ! do you know what an where the BCM is ? The BCM - body control module !
Body Control Module (BCM) location
Under the I/P below the radio on the right side of the center console .19
EPS/STR WHL CNTRL
2A
Electronic Power Steering (EPS) Column Assembly and Inflatable Restraint Steering Wheel Module Coil
60 amp EPS fuse which is #1. (under the hood fuse box- check the diagram under the hood)
**Never Never bother with a BCM circuit unless you know what you are doing!
