SOURCE: volume
I had this problem and checked the main wire going from console to bass unit, it was loose from where I had moved the unit to insert another device (RCA Jacks). Apparently if the wire from the unit is loose, it over - rides the volume and by default adjusts it to 30. Additionally, I reset the system console and bass unit console, during this process. Try this, it might fix your problem.
SOURCE: The sound/volume is not working properly on our
Make sure the device it is connected to has its audio properties setup correctly. If this is a cable or satellite box, most of them have a volume output level. Changing this will change overall volume.
