#24 acer am1610 manual - PDF Library Connecting
66.11.115.127/acer-am1610-manual.html
50+ items - pdf download about #24 acer am1610 manual download and ...
Books Title
File Code
ACER AM1610 ED2180A MANUAL Pdf Download
d6dd3 c44e6
Acer AM1610 UD2180A Manuals
b5197 d91d1
SOURCE: BLANK SCREEN-ACER ASPIRE 3661
You can check the little indicator light on the notebook.
If the hard drive was dead, that wouldn't cause the display to go blank.
If your problem was with your hard
drive, you would still get the BIOS screen and then a message about
being unable to load an operating system. So, I doubt if that is the
problem.
My guess is that you have a relatively serious motherboard, video card, memory, or CPU problem.
When you turn it on, does it beep ? If so, how many times ? You can translate these beep codes at: http://networking.ringofsaturn.com/PC/beep.php
__________________
SOURCE: acer blank screen problem
Your new computer has a defective screen. Return it to place of purchase and return it.
SOURCE: acer aspire 5315 doesnt boot blank screen
When you power up the laptop press F1 or F2 or "del" key to enter in bios setup.
Then check your harddisk is detect or not?
Then also make sure SATA option is disabled in bios.
Then go to boot option and set first boot device as your harddrive.Then save settings and exit.
But if you even not able to enter in bios then you have reset bios settings and Refix RAM memory .
For that open back cover fo laptop and find cmos cell on motherbord pull it for 10 minutes so all settings of bios goes to factory defaults.
Let me know if you need more assistanse.
Thanks.
SOURCE: No display in Acer aspire 4520g laptop
Have your laptop check up the technician, it has somethingt to do with your video card
SOURCE: Acer Ferrari 4000 power up with blank screen, no
If you cannot "press DELETE to enter setup", then it's the motherboard, or the battery, or the AC power-supply that has the problem.
Since it's likely that at least one of the battery and the power-supply are working, it's probably the motherboard (or the CPU on the motherboard) that is failing.
Take the computer to a qualified technician.
Replacing the CPU is possible, and is not very expensive.
Replacing the motherboard is possible, but is very expensive
(a few hundred dollars for a replacement motherboard, plus $100 for the technician's time to disassemble/replace/reassemble).
The only "good" news is that your files on your disk-drive probably are intact, and can be read and transferred to a new computer.
Of course, you can try to sell the "dead" computer on eBay, so that somebody else can "frankenstein" your computer with their computer, to combine two dead computers into one working one.
