Question about Sony Playstation 3 (PS3) Console
I plug in the red blue and green video cable and the my T.V says no signal, what could be the problem the cable or the console itself?
    Problem Solver:
  • 5 Answers
This could be the result of the cable malfunctioning. I would try buying new AV wires and if that does not work it may have something to do with being an HD system. If the playstation is doing this on an HDTV you may need and HDMI cord to get it to work...
Posted on Jul 12, 2009
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
How can i connect a video camera to play through tv. my camera cables are red-white-and yellow. tv. is white-red- green-green-and red.
Your camera has three cables, red and white for stereo audio, and yellow for what is called composite video. Composite video puts the three color signals into one composite signal. Your TV sounds like it has a component video connection, which wants all three color video signals separated onto three plugs. They are usually color coded green, blue, red. Not sure if you mistook a blue outlet for green..... In any case, on my TV, it will allow me to connect a yellow composite signal to the green component jack, the first (leftmost) of the three component video jacks. Not sure if your TV will work this way, but it is worth a try. Otherwise, you can look up accessories for your video camera and see if it can output true component video and stereo audio, but I tend to doubt it will.
Aug 27, 2014 | Televison & Video
Samsung tv plugging the red white and yellow cables but getting only sound and black and white picture
Hi,red-blu-green is a component signal....but red-white-yellow is a video and audio signal....component and video-audio is a different signal.You can not
Apr 14, 2013 | Samsung Televison & Video
How do i wire red white and yellow rca to an xbox 1 av plug. my av plug has blaack white orange and green wires
In the old school standard AV: Red and White are usually audio channels (Red:Right - White:Left), Yellow is video.
Orange can be coax audio, (both L&R channels in one cable). Before digital (optical) came out, some receivers actually had a coax (orange) jack in the back. Radio Shack sells a splitter if necessary.
In higher resolution systems video is separated into three colored cables: RGB or Red, Green, Blue
called 'component' video. The green cable carries Yellow, the blue cable carries (PB) Blue and the red cable carries Red (PR). And with today's tech, the component signal is carried YCBCR as (digital video.) cf. http://en.wikipedia.org/wiki/YPbPr
Component 'wire colors' are there just to remind us. If your TV has "Component" input. Try green to green, white to yellow and black to red. Orange to audio (splitting L&R if necessary)..
Also, here is a PS3 link that might help: http://www.ps3hax.net/showthread.php?t=9238
Good luck !
Apr 23, 2011 | Video Game Consoles & Games
I see no red and green colors on screen projected by pjtx 100, the rest of the colors are visible.
If you are using a component video cable (Red, Green, Blue) you may simply be missing the Red cable. It may not be fully plugged in.
You can verify that this is the case by: 1. Unplugging all video cables 2. Plug in the green cable, you should see a black and white image. 3. Plug in the blue cable, you should see some colours coming through. 4. Plug in the red cable, you should see all colours properly.
If not, unplug the blue and red cables and plug the blue cable into the red port. The colours will look incorrect, skin tones will be blue. If the colour comes through the problem is the cable. If the colour does not come through, the problem may be the projector.
Feb 28, 2011 | Hitachi PJTX100 Multimedia Projector
No sound on tv and black & white
The red, blue, and green are the component cable hookups. What you have w/ red, white, and yellow is called composite or on most TV's (AV) See if the TV has a side port for like a camcorder, etc. It will not work by hooking into the red/blue/green as they are different signals.
It is possible that your yellow jack may be separate from the red/white audio left/right jacks.
May 04, 2010 | Sony PlayStation 2 (PS2) Console
Only shows in black and white
check that the cables are firmly plugged in, if using a rgb cable otherwise known as hd tv cable. check they are in the sockets properly otherwise you will not get full video signal, red green and blue are used to make up video spectrum. this is very common with plugs not pushed in fully.and can be a pain to detect. unplug and tehn plug back in firmly pressing into soicket.
Jan 02, 2010 | Nintendo Wii Console
How to hook up ur xbox 360 to ur tv to play ur xbox 360
if your using the hdmi cables you have to plug in the green, blue and red cables into the corresponding sockets on the tv, the plug the red and white ones into sockets which are not in the same area as the normal red white and yellow cables, there should be a row of sockets at the bak of your tv:
Green
Blue
Red
White
Red
Dec 22, 2009 | Microsoft Xbox 360 Console
The wires from the wii to hook into my samsung t.v. do not match is there an alternative wire configuration that I might be able to obtain?
The cables that come with the Wii are composite video cables with the standard red, yellow and white cables. You might be trying to plug them into the component video input, which has red, blue, and green.
Check your TV to see if you have any red, yellow, white inputs. Use that input if you are using the cables that same with the console.
Alternatively, you can buy component video cables for the Wii. This will be for the red, blue and green input. This will provide you with higher definition (480p vs. 480i) and a slightly sharper picture.
Good luck.
Nov 29, 2009 | Nintendo Wii Console
Do i need all cables (red green blue) for the xbox360?
no just the other 3 will do red,green,blue are for hd
Jun 29, 2009 | Microsoft Xbox 360 Console
I have a Sanyo HD TV and my Playstation 2 has the red white and yellow jacks but when I plug them in I get no color. If I move them to the bottom red jack and the top green and blue jacks it works but...
the red and the white cables are the left and right sound
the yellow one is the only one sending a picture signal
plug it into the video in...which should be yellow on that tv, the green and blue jacks are for another type of video connection
Jun 28, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
112 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
