If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
SOURCE: programing rca remote for dvd/vcr combo
all you have to do is press and hold code search when the light shows up let go of code search then press VCR and it will blink onces and let go of VCR and press OFF/ON about 50 times and then press enter onces and there you go
SOURCE: need codes for rca tv using ge universal remote
Here Are Some codes 000, 003, 004, 005. 006, 007, 019, 096, 098, 099, 100, 101, 102, 103, 129, 179, 181, 188, 190, 203, 212, 233. For t.v.'s............Hope this is help full.. : )
SOURCE: codes for Daewoo TV & DVD on Ge UN Remote #
go on their website there is always a list of codes
SOURCE: I have a ge universal remote model #24110R need tv code
http://www.jascoproducts.com/support/universal-remote-codes.asp
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
2. Press and hold the CODE SEARCH/SETUP button on the remote until the
INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming (TV, VCR,
DVD, etc.). For AUX, press AUX then the device button you are assigning to
AUX. The INDICATOR LIGHT will blink then remain lit.
4. Enter the three or four digit code for your device using the number buttons in the
GE Universal Remote. After your code is entered the INDICATOR LIGHT will
turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the POWER
button. Your device should turn off
OK
