Instructions for operating rv awning
Manual or electric. If electric press the switch located inside the unit. If manual, you will need to go to each arm and press the release clips to unlock the arms (usually black but may be a lift up lock). Next tank the long rod with a loop on one end and a 90 deg hook on the other. Toward the front of the coach at the top of the awning you will see a small lever on the awning. Use the loop end of the rod to pull the lever down. Take the other end of the rod and insert it into the black strap that should be barely hanging down and pull down as you back away. This should pull the awning out. Once pulled out all the way, go to each end of the awning. Close to the wall of the RV there should be an arm hanging down with a knob on the back of it. Grab the bottom of the arm and slide it out and clip it into the end of the extended awning arm. Push down on the lower arm to tighten the fabric and then tighten the knob. Once both ends have been tightened then on the lower arm there will be a pull out handle in the middle, pull it out to release the lock pin and lift the outer portion of the lower arm up to raise the awning to the desired height. Repeat for the other end. If it is raining or windy put the awning away. DO NOT LEAVE IT OUT! The wind will catch it like a kite and rip it off of your trailer. Rain will fill it up like a swimming pool and collapse the center tube and trap you inside of the RV.
Did you ever get this figured out?
