Question about Radio Communications
Kenwood TS50 - Max volume gives very low audio while receiving
Volume is on max but there is very low audio while receiving. This then changes and suddenly the audio is very very loud. This lasts only short time /some minutes/ and then the audio is again very low and I can hear only at max volume. Transmitting seems to be ok as I get quite good reports
While bad receiving the volume button is in position on
10 o clock / very, very low audio/
12 o clock /low audio/
15 o clock /poor but able to hear audio/
Suddenly it changes into normal functioning and it works properly.This normal state lasts very short time /minutes/ and most of time /hours and days/ the reception is poor.
    Sergeant:
  • 400 Answers
It sound like a bad reostat in the volume control. if its under warranty send unit back to kenwood and have them replace the volume control, and possible speaker involvement.
Posted on Jul 12, 2009
Hi i have same problem as nalim july 12,2009 as regards rx audio,but only in ssb and cw mode,can you help, baz
Posted on Sep 02, 2009
Max volume to low
Check the settings of the monitor for audio volume. Also check the individual volume control setting for the applications and system sounds. Or call ViewSonic technical support for assistance.
Jun 15, 2014 | ViewSonic Computers & Internet
NO SOUND OUT OF RECIEVER, TURN VOLUME TO MAX AND CAN HARDLY HEAR ANYTHING
TURN THE VOUME CONTROL DOWN TO SOMETHING REASONABLE. MAX VOLUME IS ONLY USED TO DESTROY SPEAKERS.
Unmute it, de-select Tape Monitor, de-select M.Input.
http://www.retrevo.com/support/Kenwood-1060VR-Receivers-manual/id/478ci953/t/2/
Jan 27, 2011 | Kenwood 1060VR Receiver
DNX7120 issue with VOL increase button. When this button is pressed once, the volume skyrockets to max, VOL decrease button does not work right away to lower the volume, nor does the ATT button. Unit...
I had the same issue. You can use the on screen volume buttons on screen to stop issue and don't use the physical buttons anymore. Watch out about a month after the volume problem started all physical buttons on my DXN7120 stopped working. There are a few reports of this online, I have not found a fix yet.
Dec 15, 2010 | Kenwood DNX7120 Car GPS Receiver
My HK 1005 incresases volume to max by itself
I had the same problem; got rid of it by changing the baateries of ma remote control.
Jun 27, 2010 | Harman Kardon DPR 1005 Receiver
I cannot get the volume to go above +13 therefore I cannot hear from the speaker son my kenwood vr-5900. It is about 7 years old.
Ok one more clarification, does the volume knob spin infinitley or does it have a set min and max. If it spins infinitley it is an encoder. What an encoder basically does is send a binary signal to a decoder chip which in turn should control a digital potentiometer. Unfortunatley one of these components may be bad.
Dec 13, 2009 | Kenwood VR-5900 Receiver
My Kenwood DPX-4020 suddenly turns up to max vol
you probably have a bad switch. you need to use a multimeter and check the resistance of your volume up switch, if less than a few meg., the switch is bad.
Oct 05, 2009 | Kenwood DPX-4020 CD / Cassette Player
Maximum Volume is set at 79 yet will max out at 60-65 depending on source, TV, Audio or DVD is anything wrong?
have you done the audessey setup or even changed the level calibration on your receiver? if so this would reduce the actual max volume on the receiver.
Feb 27, 2009 | Onkyo TX-SR606 Receiver
Max. VOLUME on Samsung TVs Too Low
Some models have a volume limit setting, check the MENU and look at the audio settings.
If this has external speakers use other speakers. If it has audio output connect them to a external amp and useing the remote adjust the volume. Check if audio settings are set to internal, external and fixed or vairable output.
Jan 09, 2009 | Samsung LN19A451C LCD TV
Kenwood VR 505 low sound in center channel
if the cables are ok and the speaker are ok also beside good setting you will have a problem of the output stage in your receiver.
May 06, 2008 | Kenwood VR-505 Receiver
WON'T CHANGE CHANNELS ADJUST VOLUME OR SHUT OFF
If the volume buttons work when using the Radio, then the buttons on the Remote are fine.
Now if the volume on your TV is set to MAX and you can barely hear it.
The issue lies with your TV.. ()
Now if I understand correctly or if I am to assume you are using a Reviever.
If the reciever is used for all volumes... If this is the case.
I also assume the volume on the TV Speakers is set to off
Therefore when you use the Radio/DVD the volume control is using the Reciever volume.
and when you switch to TV it uses the TV volume thus the TV volume is not gonna work as well.
2 scenarios
1 The TV volume even at max is not giving you enough power to get the low receiver volume
2 the Receiver volume is at max and barely audible.. if this is the case just manualy adjust your TV volume to get it to a decent sound level.
Hard to explain but I know the 2 issues can be fixed.
Apr 21, 2008 | Logitech Harmony 550 Remote Control
Radio Communications Logo
739 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
