Question about Maytag Washing Machines
The spin cycle is not removing all of the water, the cloths are very damp, you have to ring them out by hand
  • 744 Answers
Hi.
this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
thank u
rate me
Posted on Jul 12, 2009
After wash clothes come out damp
Washing machines wash clothes not dry them. They have a spin cycle that removes most of the water but you still have to put them in the dryer.
Jul 16, 2014 | Whirlpool WTW6400SW Cabrio Washer
Clothes are wet after spin cycle
U need a technician for that... there is a problem with the "flow valve" sorry can't help u out much with that... but maybe u can visit this site and hit the like button... www.facebook.com/muktidayasewa
Jan 13, 2014 | Amana 3.2 cu. ft. Top-Load Washer
Kenmore washer model #417.42042100 is not spinning the clothes all the way.
First you need to open the cabinet and remove the boot from the tub to the pump and clear the filter. Try that then run a cycle and post back the results.
Dec 05, 2012 | Washing Machines
Washer is not ringing all the water out of the clothes and the display reads sd
Don't worry your washer is not the only one.Are you using a HE detergant,and bleach.first remove clothes am sorry there wet,my wife has gone through this problem,if the door don't open push the start button a few time you should hear the pump trying to drain,have a flashlite in hand and is the water going down?
when it starts to spin the water has droped to a point wear it starts to spin.After the spin cycle bleach machine or sanitize, also if it having a hard time to balance to stsrt spinning.I have seen it go 23min. till the water got out of one of the clothes to balance and start spinning ,these machines are very sinsible its what we payed for a washer with a brain.
Jul 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My machine do not spin the clothes
is your washer a direct drive machine, if so check the direct drive coupling down by the gearcase, pump and motor. it may need to be replaced.
Oct 13, 2009 | Kenmore Washing Machines
I have a Kenmore frontloading washer, model no. 417.42042100. At the end of the wash cycle, the clothes are still very wet; that is, still SOAKED with water, even though all the water has been drained...
HI. your unit is equipped with a spin control board. this board, if damaged, will not initiate an adequate spin. This will not allow for proper drainage and drying of the clothes. The spin motor regulates the rotation speed during the spin cycle. It seems to be the culprit at this time. Have the spin board replaced asap.
This part will usually cost around $150.00 at the most.
Aug 27, 2009 | Kenmore Washing Machines
Spin cycle not removing enough water from clothes
your manual states that it can be caused by cold rinses and or spin cycle not getting completed. please try to rinse in hot or warm and see if that does not solve your problem
Dec 20, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Nov 09, 2007 | Admiral AAV7000A
Water in Outer Tub
My washer does this too and I called Maytag and was told it was normal. I don't like that answer, though.
Mar 06, 2007 | Maytag Neptune MAH5500B Front Load Washer
AMANA WASHER WILL LEAKS WATER IN TUB AFTER SPIN CYCLE.
Cylon, sounds like you need to replace the water inlet valve. It's not seating and weeping water. For series 10 the part number would be 40097701. Not that hard of a job. Catriver..post back.
Feb 20, 2007 | Amana ALW880WH Top Load Washer
Washing Machines Logo
20 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
