Is there a wiring schematic for the wires in this drill? 7190 type 2.
Http://servicenet.blackanddecker.com/Products/Detail?isId=true&productNumber=7190&selectedType=1243 Detail
SOURCE: Loose white wire in B&D 7190 Type 2
If you look at the switch you will see a hole with a brass coloured contact inside. These are grip type connector where you push the wire in and it grips it. Try pushing the wire into the hole and see if you can pull it out again gently. If it holds you have fixed it.
SOURCE: When replacing cord on black & decker 7190
If you look at the trigger/switch mechanism, you'll note little lettered ovals on either side at the bottom/base where the wires go. The black (hot) wire from the plug goes to the side stamped "LINE", and the white (neutral) wire goes to the side stamped "LOAD"
