Question about Toshiba Satellite L305D-S5881 Notebook
When i start my laptop in any mode, the screen is bright black with the arrow, and i dont have cds
Black screen won start
Look for a brightness up/down arrow in the F1 - F12 buttons on top of your keyboard.
Try tapping on the up arrow for brightness, also try tapping it while holding the Fn (function) key of your keyboard.
If it seems like no power is going to your screen, you may need a new screen or a computer technician to look at it. If someone you know is good at hardware, have them check the power connection before paying a store or technician.
Feb 06, 2014 | Toshiba Satellite L305-S5933 Notebook
Restored laptop to previous date due to virus protector jumping on my screen and not letting me operate the laptop. Let laptop sit while it restored, and went straight to black screen. What can I do?
If you have sensitive and important data here, best solution is to get your harddrive to your local IT specialist for backup and then Windows reinstall.
But if you dont have any important data on it just reinstall Windows and it should be OK If reinstall dont solve your problem then it might be a hardware related problem
May 02, 2011 | Computers & Internet
Acer 3680 No display when computer is powered up. Tried the brightness buttons, did the Function F5 key combo to make sure it wasn't set to external display, it wasn't in sleep mode. Are there any other...
take reboot off f2 push f2 3 or 4 times if screen is black when lap top start push f2 then use arrow keys on key board then you will change boot log to f12 now pushf10 to save settings and enter exsept now when it starts up again push f12 now its going to ask you 3 questions go to 2nd question then push enter.
Feb 15, 2011 | Acer Aspire 3680 Laptop
Monitor black out
Someone adjusted the brightness on the system for AC power mode. Turn on the system with the AC power plugged in, hold down the "Fn" key in the lower left of the keyboard, then press the up arrow in the lower right. This will increase the brightness; set it at whatever level looks good to you.
Jan 14, 2010 | Dell Vostro 1500 Notebook
Laptop screen stays dark. Hve tried the function and arrow buttons but no joy
Press the FN button and hold it down and then press the brightness functions. Most people dont know that also could just be the monitor or you have it on battery saver mode which will make the screen seem dark check the batt icon that might be the problem
Jul 26, 2009 | Acer Computers & Internet
How do i adjust the screen brightness on a toshjba satellite 4030 cds laptop
To adjust screen brightness on a laptop press the Fn key at the lower left of the keyboard and then press the arrow key's at the lower right of the keyboard.
Apr 17, 2009 | Toshiba Satellite 4030CDS Notebook
Get black screen with no response
2 questions do you press one of the function keys if you do it will do that and if you dont it is because of an so called "improper shutdown". what you want to do is simply move the arrow keys left or right brfore the menu. if that does not work press first safe mode wate along time and after just do start windows normly and wate along time
Nov 25, 2008 | Computers & Internet
Keys dont work.alternative way to change brightness?
Yes you can go into your display properties and look in the settings tab and look for advanced click that and open color tab or the overlay tab, color tab should get your brightness turned up, And if you can't see you can go into your bios and adjust your brightness from there and get it back to where you can see it if you can't write me back here so we can try another method. Ok I hope that helps you out somewhat, Oh yeah you can also hook up an external key board into your usb connections and you should be able to work everything from that too.
Jan 15, 2008 | Dell Inspiron E1505 Notebook
Acer Aspire 5630 screen brightness adjustment...
How do I adjust my brightness or contrast on my laptop? See our brightness definition for a visual example. Finally, most laptops only enable users to adjust their brightness of their screen.
Click on the above Link, Good Luck, Please dont for get to Vote.Thank you.
Dec 15, 2007 | Acer Aspire 5100 Notebook
Start-up problems
From the sounds of it, you have a problem with Windows or your HD. If it doesnt start in safemode, I'd suggest these things in this order (and each step being more severe, so try your pc after each): take out your battery and unplug the power supply then hold down the power button for about 2 min, resetting your bios to defaults, a HD self test, and then reinstalling your OS via recovery cds or partition. There is a lot of information on how to do all of that on HPs techsupport site. If you dont have a partition, you never received cds, and you didnt make recovery cds, then your going to have to order them from HP for about 20$-40$ Good luck
Sep 20, 2007 | HP NX9010 Notebook
Toshiba Satellite L305D-S5881 Notebook Logo
56 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
