Question about Sharp Televison & Video
Sharp Aquos won't display color with wii or dvd...only from dish
Will display color with DISH (regular tv), but when hooked w/ input 1 or 2, (for dvd player and wii ), tv won't display any color. only black & white! HELP!
  • 53 Answers
SOURCE: My Sharp Aquos 46" LCD
Digital inputs on Aquos TV's are "always on," usually the HDMI inputs and DVI inputs. As opposed to analog inputs 1, 2, or 3, are only activated once something is plugged in.
Try plugging in another HDMI sources into input4 or 5, if its still not working, the TV needs a new Main Board. Try calling Sharp 1-800-237-4277 and locating a local service center in your area.
Posted on Mar 14, 2008
gtaplytmpt
  • 90 Answers
SOURCE: Hooking a Wii to Dish Network reciever(not a hd tv)
It sounds like you have a pretty new TV. This means that there should be multiple AV jacks in the back for setting up your many components. Plug in the receiver into #1, the Wii into #2, and any other equipment you may have (DVD, VCR etc.) in the same way. You should then use the original TV remote to switch between Video 1, 2, 3 and so one for each compnent you want to use. The button on the remote will be labeled video, tv/video, input select, or input, something like that.
Hope this helps!!
Posted on Jan 02, 2009
  • 151 Answers
SOURCE: Dish Network connection and surround sound
HI, connect audio output from tv to system,you may have to turn this on or turn up in tv menu for some sharp tvs,this should get sound for tv and dvd and anything else you hook up to tv.
Hope this helps.
CABLE GUY.
Posted on Mar 29, 2009
SOURCE: hooked up cable box, wii box and dvd player to new
Connect the Wii and the DVD player to different ports on the TV to and any other device to the port in which the Wii and the DVD player were connected to check if the issue is with the port.
If other devices also display in black and white after connecting them to the port to which the Wii and the DVD player were originally connected then the ports require servicing.
Posted on Dec 01, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: my tv turns off all by itself
If it can turn on again, it may ok. and you can enter to the service made to see what error is.
Posted on Apr 17, 2010
I have dish and I want to know what to set my Tv on to watch a DVD? How do I get it started?
You just hook your DVD player up to any of the inputs on the back, then change it to that input. The dish should have no effect on watching a DVD off a different input. So take the Red, Yellow, and White RCA cables, put them in input 1, 2 or which ever. Change your T.V. to which ever input you placed it on and you should be set.
Jun 20, 2011 | Sharp 32C241 TV
I need a dish network code for a 52" Sharp Aquos.
Hi deidrapleasmy name is Mike Houston of DISH Network and I was going over your post and thecodes for your 52" Sharp Aquos are 628, 739, 521, 629, 741, 679, 112, 605, 625,111, 608, 740, 526, 585, 607, 652, 654, 655, 658, 669, 670 and 674. I will sendthe link to help with the setup for the remote to TV. http://www.dishnetwork.com/SupportSection/remote-control
Feb 14, 2011 | DISH Network IR Remote Control
My sons Sharp tv was working for dish but i was trying to make it work for a dvd i did something with the imput but i put it back on the right input and it still not reading the dish box works because it...
Make sure the input is hooked in properly first, also make sure it's coming out from dish to inputs on tv and turn tv to the input you are hooked too and then try turning on dish and off to see if you can see anything
Dec 07, 2010 | Televison & Video
SNOWY screen--can't find the right channel for Dish Network
Press INPUT button on your TV remote and select right input.
Nov 02, 2009 | Sharp AQUOS LC46LE700 46 in. LCD HDTV
Hope this helps.
CABLE GUY.
Mar 29, 2009 | Audio Players & Recorders
Hooking up a dish network to my tv
Well, I don 't have that T.V. but I can tell you that you may have to go to your menu and look for your channel setup and change it to another channel output. If that doesn't help then have it search for channels.
Jan 30, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Hope this helps!!
Dec 29, 2008 | RCA HD52W59 HDTV Projection Television
DVD/VCR hook up to HDTV. No audio on DVD or VCR, no video on VCR
When you use component audio, it may shut off the side a/v audio settings. Try restoring all defualts (any changes you have made will be lost by doing so) according to p. 32 of the manual:
Menu --> Setup --> Reset --> Yes
-Tha Mp3 Doctor
Dec 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos vertical black line
Call Sharp at 1-800-237-4277. There are firmware upgrades that this lcd needs to resolve issues. Good luck!
Nov 15, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Hooking up tv to dvd player
You will probably have to use your tv remote and change the input for your dvd. It's usually video 1,2 or component 1,or 2
Jul 01, 2007 | Insignia IS-LCDTV32 32 in. Television
Open Questions:
Did I install the t-con board wrong? I was having flickering on my sharp aquos and replaced the t-con board. Now I get no picture. After I thought the new t-con board (verified exact same part, ordered on tv parts today) was defective because I got no picture after installing it, I decided to swap back to the original t-con board. when I did that I still had no picture. Which made me think I installed it wrong. I undid the cables, reinstalled the ribbon and the menu appeared on the TV when turned back on. So that made me think something wasn't set right w/ the ribbons when I installed the new t-con board. So I swapped back to the new one, and after trying to make sure I set the ribbons correctly, I still have no picture. So then I went back to the old t-con board (because as I just verified, it was working after I re-installed it the 2nd time) and now I STILL have no picture. I swapped back and forth a couple more times and I can't get any picture to show up. So that makes me wonder did I possibly fry something (I was very careful, kept myself grounded, didn't get rough w/ the ribbons, etc) or is it something like the ribbons are just extremely sensitive and maybe they're still not set right (they're very hard to reach)? Any thoughts on how I could test the t-con boards to check if they're good and I didn't blow something? I saw a video that it's possible w/ a multimeter but I'm not sure where the fuses are on the board or which area to test. Thanks in advance.
Jan 15, 2019 | Sharp Televison & Video
Televison & Video Logo
793 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
