Top load washer will not drain after a rug was washed in the washer and then torn into pieces inside.
    President:
  • 1,136 Answers
Hi, Please get me a model # so I can look this unit up and give you direction on how to get to the pump and hoses.
Vic
Posted on Jul 12, 2009
After washing bathroom rugs, my Frigidaire Affinity front loading washer would not drain the water out or refill with water
Often washing things like rugs and matts can cause real problems for the drain pipes on you machine. Have you tried clearing out the drain plug, located at the bottom of the front of the machine? If that doesn't work, the whole drain hose from the drum will be blocked.
thanks
www.recycledrum.com
Jan 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
I washed a rug and the rubber backing came off in the machine and is now not draining?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 29, 2010 | Kenmore HE2 Plus Front Load Washer
I washed a rug and now it won't spin or drain
heatman101
Oct 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Hi..we washed a rubber backed rug and the rubber came off and the water will not fully drain. we washed several empty cycles since with no results
You will have to take the hoses off between the tub and pump, and the pump and weall drain. They are packed with rubber. Oh, don't forget to clean the inside of the pump too. Run clean water through all hoses and the pump before reinstalling and you should be fine. Don't wash rubber backed rugs in washers unless you go to the laundry mat. This should be put in the maintenance guide of your washer book, but I've yet to see it.
Feb 03, 2010 | Malber P21 Front Load Washer
WASHED RUG IN MY NEPTUNE WASHER. rUG CAME APART. washer won't drain all the way. ND COMES UP.RUG WAS SHAG TYPE.hELP!
You will have to clean up drain system in washer. Get the rug pars out. A wet vac is a useful tool here.
May 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
Washer will not drain
Remove the front panel. Remove the drain pump and clean the debris from the drain line and the drain pump.
The service sheet is located inside the control console with the procedure to remove the panel.
Mar 02, 2009 | GE WBSR3140DW Top Load Washer
PAV2300AWW
pump is likely not clean yet
there is a chance that the pump impeller is loaded with lint, inside the pump body
not sure about front loader dissassembly,
usuallly front panel removes and the pump is accessible on the front side of the motor retained by two spring clips.
if you clear the muck quickly the lint wont damage the impeller
Nov 05, 2008 | Maytag EPIC MFW9700S Front Load Washer
GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
