Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Konica C350 What does a Malfuntion Code C-0500? My machine is locked. How to I make it run again? Thanks, travelneworleans@aol.com
    Champion:
  • 214 Answers
Should mean that fuser temp too low or high, try reboot. If just reboot wount help, hold down utility or stop key, then you should be abel to do trouble reset.
Posted on Dec 05, 2007
Why am i still getting error code 0500 i bought a new fuser unit.
You need to reset the machine, the new fuser does not reset the machine.
May 03, 2014 | Konica Minolta magicolor 1690MF All-In-One...
C0500 error code
First open the right side cover where the image unit is located. Check the two latches that latch the door ensure they are not broken, especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with the copiers on it on the left side of the screen in the middle you will see a small "." When the dot appears touch 3 button. Then the machine will continue to the code screen. Press the Utility button you should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day.
C-0500 code mean no power to the fuser inside mid cover front is a micro switch that provides the power to the fuser unit
Jan 11, 2014 | Konica Minolta Di3510 Copier
0500 ERROR CODE
I am also facing this trouble, with Di3510. some time machine work for many copies fine. then suddenly the 0500 error code appear. I checked complete fuser unit... Both lamps are ok, Thermo switch is ok, i checked both thermistors and in my view they are ok (checked with multimeter while warming them). I first reset the code as mentioned in the service manual of this machine. the code can remove but it comes back after some time. I checked the Electricity voltage as this machine is 120v input. Voltage are ok. Then i ask my Electronic board expert to check the Power supply and he told me that the power supply is ok... just some dry sold he found. So until now i am not able to detect the trouble even though i arranged another fuser unit of the same machine and it also gave the same error code c0500. As i am a Technision of copiers. Please give any good suggestion if any one have. Thanks
Jan 09, 2014 | Konica Minolta DiALTA Di200 Copier
Malfuntion code c-5102 for oce imagistics cm2520
C 5102 - Main motor malfunction.Check the I/U unit gears,Fuser unit gears it is a mechanical locked problem.
Feb 01, 2013 | Konica Minolta bizhub C250 All-In-One...
P 0500 P 0462 P 1693 Codes on 2001 Dodge Ram 3500 5 speed 5.9L Diesel. Intermittent miss while cruising 40-70 mph. Will miss and sputter for a while then clear up and run fine until it decides to act up...
Hello Sir, The codes that you provided us means the following :----
  1. Code P 0500 :---- The speed sensor is not working or malfunctioning.
  2. Code P 0462 :---- There is a low input in the Fuel Level Sensor Circuit.
  3. Code P 1693 :---- This means that the Turbo Charge Control Circuit is Malfunctioning.
You have to call a mechanic to rectify these faulty areas. Only a certified mechanic can fully recover performance.
Please reply me for further assistance.
Thank you Sir, Have a nice day.
Oct 19, 2009 | 2005 Dodge Ram
C-0500 code on bizHub 163
ARE YOU CONNECTED TO A LAN CARD OR NETWORK OF ANYKIND.
GO ON LINE AND TYPE IN
MINOLTA DI2510 B/W COPIER C-0500 ERROR MESSAGE
ENTER
ROD
Feb 05, 2009 | Minolta DI2510 Black and White Copier
C 0500 IN DI 152
turn machine off hold down stop botton while turning on power ,hold down untel machine comes on
good luck
Sep 30, 2008 | Minolta Office Equipment & Supplies
Lg ux5200
try the last 4 digits of your mobile number.
Feb 12, 2008 | Cell Phones
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
179 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
