SOURCE: Tv cuts off and green light flashes
I went thru this a couple of days ago. The repairman change the bulb and my TV was fix in 15 Min. I too have a Sony 60 inch WEGA. Now that I know I can change the bulb myself, but there's a hazmat issue on the bulb. goog luck.
SOURCE: Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
SOURCE: Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
SOURCE: Samsung Rear Projection 47" TV goes into stand by on start up
I am sorry to disappoint you but a TV problem can only be fixed by electronic technician. If you want to do it yourself, you would have to learn electronics. Start by learning basic electronic, and then read a book on how to fix televisions. Without knowledge in electronics, you won't be able to understand a book on fixing a TV. I have been fixing TV since 1998, and I started after dropping out of electronic engineering class. I learned most about electronics on my own, and you can too.
SOURCE: tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
