Question about 2wire (1000-000057-000) Modem
DSL modem no power in house, OK at shop, same cables.
Got a DSL modem from a friend - working well for him - and plugged it on. No lights came on. Took it to a shop, they plugged on with my cable and the lights came on. Back home lights also came on when I tried myself but few hours later when I tried to set it up I got no lights again. Tried multiple outlets, same result - no lights. What do you suggest?
  • 43 Answers
Well, by process of elimination, it sounds like it may be a problem in the wiring in the house. Your best bet may be to test your outlets for proper wiring (ie. hot/netural faults), and for cycle rate (in hz, 60hz is nomal). I would also look into a surge bar that is built for normalizing power (Often called Power Cleaners). If you have older electrical service into your house (fed from a pole) or if you are in an apartment or condo type building, there may be line problems with the power supply. Basic outlet testers are under $10 and really handy to have around if you do any sort of electrical work, but the surge bars can be quite pricy. I would look at other outlets in the house that have similar AC/DC converters attached (like cordless phones, laptop computers) and see if it works in those outlets. Really a very strange problem, and may go deeper then just the modem itself.
Posted on Jul 17, 2009
Cannot connect to my Internet. On my 2Wire modem at home, The Power LED light is solid green, the Ethernet LED light is green, the DSL LED light is continually flashing, and there is NO Internet LED...
With the DSL light always flashing, it means that either the ADSL signal (synchronization) does not reach your modem, or your modem cannot 'read' the signal.
You need to determine if the problem is from one of the following places :
  • outside of your house (your land line or ISP equipment) or from the modem;
  • your telephone-cable inside your house or
  • one of your equipment;
Try the following manipulations to determine from where the default comes :
  1. Determine if the problem is in your house or on the land line
    • Unplug each and every equipment which is connected to your telephonic installation (Fax, phones, answering machines etc);
    • Using the shortest telephone cable (RJ11) you possess, plug only your modem to the main telephone jack of your house.
    • If the DSL LED still flashes continuously, the problem is somewhere between your ISP's equipment and your house. You should call them and expose the situation. At this stage, you can't do much else.
  2. Determine if the problem is in your house installation
    If the DSL LED lights up when it is plugged to the main telephone jack, then it is either one of your equipment which is at fault, or the house installation. To pinpoint the problem, do the following :
    • With all the other equipment still unplugged, try the modem on all the other telephone jacks you have around the house.
    • If the DSL flashes continuously on one of the jacks, you will have found the source of your miseries. Depending on your ISP's terms and conditions, you will either have to call them of call for the services of a third-party technician to solve the problem.
    • If the DSL lights up correctly on all the telephone jacks, then your house telephone installation is good. Proceed to the next series of tests.
  3. Determine which equipment is at fault
    • Plus your modem to one telephone jack and wait for the DSL line to light solid.
    • Use a splitter (ADSL filter) to plug the equipments you possess (telephone, fax etc) one by one. Verify each time if the DSL LED is still lit or flashes continuously.
    • If one of the equipment causes the DSL LED to flash, it is that equipment which causes your problem.
    • If every equipment causes the DSL LED to flash, the it is the splitter (ADSL filter) which is causing the problem. You can confirm this hypothesis by testing each and every ADSL filter you have in your possession.
    • Replace any faulty equipment and you should have eliminated the problem.
If nothing of this solves your problem, you won't have any choice but call you ISP. Don't hesitate to tell them all tests you will have done.
May I also make some recommendations :
  1. Use a power surge protector (not a UPS though) to plug your modem to the electric outlet BUT plug it directly to the telephone jack;
  2. Make sure your modem is plugged in as far as possible from UPS, television, etc.;
  3. If possible, don't plug the modem in the same electric outlet as other equipments;
  4. Don't use any telephone extension cable to plug your modem to the telephone jack.
Hope this helps you. Let me know what happens next.
May 11, 2011 | 2wire (1000-000057-000) Modem
We have 2 desktop pc's. One in one room and the other in another room on the far side of the house. Both are connected to the same telephone line. The 2wire homeportal 100 hg died and I went to Radio Shack...
well in a hard spot if your using dialup as means of connecting to the internet then only one PC at a time can use dialup connections now if say it was a DSL modem then from the DSL modem or DSL Router Modem you would need RJ-45 cables from the DSL router modem to the two PCs
Apr 22, 2017 | 2wire HomePortal 1000HG DSL Modem and...
What to do if dsl light is blinking
This likely means that your DSL modem is not trained up with the DSLAM. - Geek talk for your modem is not connected to the phone company's equipment properly.
1.) Remove power from the modem
2.) Remove all devices (including the DSL modem) from all phone jacks in the house.
3.) Add the DSL line back to the wall jack, taking care to plug the wall jack into the correct jack on the DSL line. (Do not use a DSL filter on your modem!)
4.) Power up the modem/
Still not working? Continue...
5.) Try a different phone jack
6.) Try a new phone cable between the wall jack and modem
7.) Call the phone company for further assistance.
Dec 18, 2010 | Siemens SpeedStream 4200 (13A4200001)...
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    Modem won't connect to internet. OS: WinXP Pro SP 3. ISP: Earthlink DSL. Modem: ZyXEL P-660R-D1 (supplied by Earthlink) connected to computer with ethernet cable. Modem includes double filter for phone...
    maybe you have to wait for your provider for them to isolate the problem, it seems that your modem got hit maybe by high surge. ask them to bring a spare modem for isolation.. there is no way for you to isolate the problem coz you've already done the basic....
    Jun 19, 2009 | Computers & Internet
    A friend gave me old 2Wire 1701HG wireless modem/router. It didn't come with power cord, cables etc. I found a 4.5V cord from old walkman that worked. Anyway, have ATT DSL service with speedstream 4100...
    That would seem to be AT&T's favorite house brand...
    Me thinks the SpeedStream was their SLOWEST
    "DSL"
    "2wire" was their next iteration of SLOW "DSL"
    Yes... You will need to contact THEM ... or whom-so-ever is your INTERNET SERVICE PROVIDER (ISP)...
    As I recall... the PRICE DIFFERENCE from one
    service to the other was about $10 per month.
    Give them your pirated modem number and they
    will need to register it as a digital subscriber
    in order for you to gain internet access.
    Carnac the Magnificent
    May 08, 2017 | 2wire Computers & Internet
    Actiontec Modem Won't Work!
    take a wire and carefully touch it to the two attachment points of the copper ring on the left side while it is plugged in. I first froze my system for 15 min then thawed out and touched the wire as instructed and all works fine.
    To open the box remove the clear soft contacts on the bottom, should be four. Using a small philips remove them and pull the box in two. Then fix according.
    Hope this helps
    Aug 27, 2008 | Actiontec (GT701) Modem
    DSL connection
    Wow, that router is at least 4 years old. I have not seen a working 2wire 1000hw for about 2 years. I would purchase an aftermarket modem at best buy or off of ebay if you want to go cheap. I have worked for ATT for about 10 years. Hope this helps
    Aug 07, 2008 | 2wire HomePortal 1000HW DSL Modem and...
    DGL-4300 resets every few seconds
    Try the following:
    1. Hook up your router like you want it to be
    2. After the WAN/Wireless lights turn off we want to HARDRESET your router.
    3. There will be a small hole that requires a pen or paper clip to press...Hold this down for about 15 seconds, or untill the power light flashes on your router.
    This might take care of it.
    let me know.
    Jan 10, 2008 | D-Link GamerLounge DGL-4300 Router...
    "fail: Test ADSL Line Sync" per AT&T Tech Readout
    hi,there are a lot of possibilities y ur dsl light wont stop flashing red, 1.could be hardware failure,2.defective lead light for dsl,3.or line issue on the network...i strongly recommend that you contact your isp or att provider so that test would be done by their tech support,...basically you have checkd all inside wirings n as you have said you even tested the nid already...have you tried changing the dsl cable or phone cable? have you tried using another modem? were you using a filter for your dsl? you have to consider also other emi/rfi or electronic interference....but most probably you might try upgrading your modem n see if your gonna get a steady dsl light...the ethernet plugs has no effect on the dsl light...its just the cable connection or line issue or defective modem...i hope this will help, pls feel free to ask if you need further astnce...
    Nov 29, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
    2wire (1000-000057-000) Modem Logo
    127 people viewed this question
    Top 2wire Computers & Internet Experts
    Prashant M
    Prashant M
    Ron Stone
    Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
