Question about Refrigerators
I have water leaking into my fridge ware is the drain hole
    President:
  • 1,136 Answers
Hi, The drain hole on most models in behind the rear panel inside the freezer section.
Remove the panel andlocate the drain hole under the evaporator coils.
Some models need an add on drain heater kit. Please get me a model # so I can look your up and let you know if it needs a heater.
Vic
Posted on Jul 12, 2009
Water leaks at bottom of fridge
The same thing happened to me then I noticed ice had formed at the bottom of our fridge. It was covering a drain hole so water was leaking out the front of fridge instead of going to the drain pan or wherever the hole goes. After I chipped out the ice and cleared the hole with warm water the leak stopped. I also fixed another leak coming from bottom of fridge caused by a loose brass connection on water line going to the door.
May 25, 2014 | Hotpoint HSS25GFP Side by Side...
Leaking and fan stops then starts?
Don't know if this will help but our fridge was leaking and then I noticed there was ice at the bottom and it was clogging a drain hole so the water ran out on the floor in front of the fridge. I chipped out the ice, melted the drain hole and slightly raised the fridge temp so the ice would not re-form on the bottom and it worked. - no idea about the fan.
Jan 17, 2014 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
GE SIDE BY SIDE FRIDGE HAS WATER LEAKING ON FLOOR FROM FREEZER SIDE
There is hole behind the freezer panel that the water should drain thru . Use a small hose in the hole and blow thru to cleam drain .
Aug 14, 2012 | GE Refrigerators
Water is leaking into the refrigerator from the freezer it seems to be worse when the ice maker is on
if it's worse with the ice maker on i'd have to say the ice maker is leaking but normally the water is from a blocked drain in the freezer.unplug it,remove everything out of the freezer,pull off the inside back wall of the freezer,melt out all the ice with a hair dryer,next you'll see a hole under the evap coil,that's the drain,you have to free it up,i use a steemer to blow down through the drain but if you don't have a steemer keep heating up the area where the drain hole is,you can try using a turkey baster to blow through the drain,when you think the drain is clear pour hot water into the drain hole,if it goes down you're done,if it doesn't keep heating it until the water drains down the hole.also open the fridge door,in the top of the fridge in the middle of the ceiling and where it touches the back wall you'll see a mold,that's also the drain,heat that area up with the hair dryer to melt out the ice in the drain.the problem is slime builds up in the drain,when the fridge goes into defrost the heater comes on and melts the ice off of the evap coil and the water goes down the drain and into the drip pan on the bottom of the fridge,your drain is blocked and the water is leaking into the fridge,the drain has to be cleared.good luck with your machine.if i can help you with anything else let me know.
May 11, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking in refrigerator and floor of a 1997 GE top freezer type,model numberTBX22P1
As the only source of water is condensation or melting food, I would check to see if there is a drain hole at the bottom back of the fridge. This hole is to drain any water into the back of the machine where it evaporates. Use a pipe cleaner or similar to poke the muck through the hole and the water will drain away. Keep this hole clean every time you clean your fridge.
Mar 27, 2011 | GE Refrigerators
My fridge is leaking water inside of the main fridge compartment. It is coming from the top and I can see water dripping out of one the hole. There are two small one inch square holes near the back top...
The defrost drain hole is frozen over.
When your fridge goes into defrost mode the water has no where to go but inside the fridge,not down the drain hole.
Turn the fridge off for 24 hours and open the doors. Let it defrost naturally to clear it out.
May 23, 2010 | Whirlpool Refrigerators
Water leaking inside fridge.
If you remove the back panel of your freezer you will notice what looks like a drain - melted water will go through a drain hole that extends to your refrigerator inside a cup that slowly drains the water through a tube through the back of your refrigerator and down the drip pan. Your cup may appear fine, but maybe there is some obstruction somewhere causing the water not to drain fast enough - so what happens is that the cup will eventually overflow - try to see if you can remove this and pass a long wire down the drain tube at the back to dislodge anything blocking or partially blocking it - see if you can also clean your drain cup, eventually small derbris accumulate. At the back of your freezer panel look for any partial or complete obstruction of the drain hole and its surroundings, which might be iced up.
I myself have had this problem for months, my refrigerator would have water at the bottom accumulate and eventually under the crispers a river of water :)
Cleaning the cup and the drain tube at the back of the fridge and the drain and surroundings at the back of the freezer panel should fix this problem. Sounds like your drain at the freezer level is plugged up and water is backing up and leaking from elsewhere !
Sep 25, 2009 | Frigidaire PLHT219TC Top Freezer...
Leaking freezer into fridge
Hi, What has happened is that the drain hole in the freezer has frozen up and the defrost water is dripping into the fresh food area.
Remove the floor panel and the rear fan cover in the freezer and you see the ice that is blocking the drain.
Be carefull when removing the ice. DO NOT use a sharp object. The best way is to use a hair dryer.
Once you locate the drain hole, you will need to melt the ice down in the drain hole too. For this, you can use the hair dryer or poor a few glasses of hot water (sopping up the water between each glass).
What you will need to do after the drain is open is to put an after market drain heat transfer kit on to prevent this from reaccuring.
Please let me know if this is the case and I can get you the right part# or even send you the part.
Thakns
Vic
May 14, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Bosch fridge KSU 44 leaking water from bottom of fridge
Check the hose or the drain hole in the back of the freezer make sure hose is connect and the drain hole is not plugged
Feb 07, 2009 | Bosch KSU49630 Top Freezer Refrigerator
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
Refrigerators Logo
132 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
