Question about Dell OptiPlex GX260 PC Desktop
DELL GX260 bootup problem
I have a GX260 that I just bought on e-bay. From day 1, every time I boot up I get the Dell screen splash, then the cursor just sits in the upper left corner of the screen flashing for about 10 minutes, then it windows comes up and every thing is ok. I checked the 4 lights on the back and they are all ok (green).
Any ideas?
  • 112 Answers
Re: DELL GX260 bootup problem
To start with I would run FDSIK from a DOS boot disk and delete the partitions on the hard drive. Then reload the operating system. There is no telling what has been loaded on the system. After the reload the DELL should boot normally.
Posted on Nov 15, 2007
0 characters
3 Points
Black screen gx260
are you hitting f2 in time during the boot splash?
Oct 06, 2013 | Dell Optiplex 755 Desktop Desktop Computer...
My dell optiplex gx 260 has a blank screen when I turn it on. The windows xp professional screen comes up then when it goes to where the desktop should show up all I get is a gray screen
1. From reading your issue it seems the video card is defective.
2. If you have received the Windows XP splash screen and then the monitor displays a gray screen then only two things have happened here your drivers are corrupt for the video card or the video card itself has failed.
3. Suggestion: install a new video card compatible with Windows XP.
4. Most Dell Optiplex desktops have the video graphics card integrated to the the mother board.
Oct 14, 2011 | Dell OptiPlex GX260 PC Desktop
Dell e310 get black screen with cursor blinking after dell splash screen. F12 not responsive. front panel shows power green and number 123 are on. Thanks
According to the any brand code correct but some time code are same and problem is differ so change slot and try reboot and go to the BIOS and disable memory module single slot check it only slot me be possible memory slot is not working dot depend on dell support form only try differ
Dec 30, 2010 | Dell Dimension E310 PC Desktop
Hi - I have a Dell 8400, fails post. Diag indicators are A,B,C green and D amber. Sometimes the screen is black with a single blinking cursor and sometimes it shows the Dell splash screen. Cannot get to...
Unfortunately the dell website (not me) is not very helpful. Here's what is says about your diagnostic lights
Another failure has occurred.
  • Ensure that the cables are properly connected to the system board from the hard drive, CD drive, and DVD drive.
  • If there is an error message on your screen identifying a problem with a device (such as the floppy drive or hard drive), check the device to make sure it is functioning properly.
  • The operating system is attempting to boot from a device (such as the floppy drive or hard drive); check system setup (see "Boot Sequence") to make sure the boot sequence is correct for the devices installed on your computer.
  • If the problem persists, contact Dell.
Apr 20, 2010 | Dell Dimension 8400 PC Desktop
Booting Problems With Dell Optiplex gx270 and gx260
Does anything show up on the screen when you access your BIOS?
Have you tried a fresh install?
Are there two video adapters installed (one integrated and the other in the AGP slot?
Oct 14, 2009 | Dell OptiPlex GX270 PC Desktop
Computer will not boot up.
Boot up your Windows XP on your drive.
Since you have been on that process I assume that you already know those things prior to this solution. I'll just continue the subject after it load all the drivers.
1) After you get the "MENU" screen that has a selection of
  • Install XP press "Enter"
  • Press "R" to repair
  • Press "F3" to quit
Select to "Install XP"
2)After you will get a End User License Agreement (EULA), then Press "F8" to accept
3) Then another menu that was stated above. Then this is the time you select the REPAIR option
If you find this Solution helpful please Rank me.
Thank you.
Mar 27, 2009 | Dell OptiPlex GX260 PC Desktop
Dell Desktop computer Disk read error
try running Hard drive diagnostics from either the F12 menu or CNTL+ALT+D at Dell BIOS splash screen
Most likely, failed HDD
Jan 29, 2009 | Dell OptiPlex GX260 PC Desktop
Very slow boot
Bruce, the Dell OptiPlex GX260 normally will be equipped with a PC133 DDR1 128MB RAM module. It is recommended that you upgrade to higher memory bus DDR1 memory module, for example, 512MB/1GB DDR 1 running on 266 MHz to 533 MHz.
Hope this helps. Make sure u come back here if u still have further request.
Jan 08, 2009 | Dell OptiPlex GX260 PC Desktop
Dell OptiPlex GX260 PC Desktop wont boot
Your cd Rom is also not working properly
Jul 04, 2008 | Dell OptiPlex GX260 PC Desktop
Dell OptiPlex GX260 PC Desktop Logo
292 people viewed this question
Top Dell PC Desktops Experts
Brian Sullivan
Brian Sullivan
Are you a Dell PC Desktop Expert? Answer questions, earn points and help others
