Question about Robert Yick Co. RanRYC168 Gas Kitchen Range
Gas oven the burner in the oven keeps getting clogged and it sets off the carbon monoxide alarm, also does not keep up baking temperature, we notice a problem when the air vent at the top starts putting out small particles and it takes longer to cook. I take it all apart and it is full of soot, it should not happen every month. Please help
  • 288 Answers
The symptoms you describe point to a cracked or blown out burner. If you can see the flame on the burner the flames should be blue and even in size.
Posted on Nov 15, 2007
When i use my oven ,my eyes and nose burns . why ?
I'm assuming you have a gas oven.
You may have a sensitivity to combustion by products like CO2 (carbon dioxide) or CO (Carbon Monoxide) that are produced when the oven operates or there could be a malfunction with the oven. You didn't specify a make or model, but it's important to keep the oven clean as well.
In either case, crack a nearby window when using the oven if you have one and see if that helps. Some newer homes are so tight that the oven may not have enough fresh air and the by product gasses are building up.
If the condition persists, you may want to call a repair service to check the appliance. Also, all homes should be equipped with combination smoke and carbon monoxide detectors. The CO detector will alarm if the gas concentration starts to build up, signaling a potentially dangerous situation.
Sep 09, 2015 | Magic Chef Kitchen Ranges
My mother has a hotpoint gas stove and when baking the oven has produced a lot of black carbon all over the oven...also the burners seem to be doing this also
the pores of the burner have been blocked by some food particles or the pores have not been cleaned since longtime,so try to remove the blockage thats creating fumes of the carbon and also try to maintain the time and temprature depending on the food u make or bake.this may help to prevent such problems in future. wish u success.
Jun 06, 2008 | Kitchen Ranges
Carbon monoxide alarm keeps going off after replacing battery
the battery door may not be closed properly. Or the mounting is not correct and the battery safety switch is still on.
Nov 10, 2013 | Kidde AC Wire-In Carbon Monoxide Alarm,...
Jenn-air jdr8895 sabbath error
Faulty range/oven parts aren't the only worry a gas range owner has; the threat of carbon monoxide is very real and should be paid close attention to when doing repairs on the range.
If your range or oven gives off soot, you definitely have a carbon monoxide problem. Soot is the result of inefficient or incomplete combustion. There are always elevated levels of carbon monoxide with soot production. Properly adjusted range/oven parts do not give off soot. You may have poorly adjusted gas pressure, the air shutter may need to be opened, or you may be supplying fuel the oven isn't designed to handle. Don't use natural gas in liquid propane stove or vice-versa.
Increase Engine horsepower.
Jun 02, 2012 | Jenn-Air JJW8230D Electric Double Oven
Are there any reported problems with the Firez 21007624 carbon monoxide detector false alarms?
I do not know of any reported problems specific to the Kidde CO/smoke alarm, but I spent a significant part of my career servicing toxic gas sensors and can give you some general advice:
1- Most important: treat an alarm as a REAL alarm and DO NOT suspect that your alarm is a "false alarm". My experience has been that most "false alarms" ARE REAL and the source needs to be identified! With Carbon Monoxide detectors, it is usually a blocked vent for a gas fired appliance- a hot water heater, furnace, or oven. Call your fire department or a service professional to make sure that there is no carbon monoxide. They have portable detectors that will be able to double check your alarm.
My advice to you at this moment is to act as if you have a real alarm condition and do not place you or others in a life threatening situation. Ventilate the room/ apartment/house IMMEDIATELY!
I will post more after I send this because you may be in a life threatening situation!
Mar 22, 2011 | Kidde Firex 21007624 Ac Carbon Monoxide...
My nighthawk carbon monoxide alaram is keep biping
Check your user manual for issues dealing with beeping alarms.
Your local fire department may be able to help educate you on the proper installation and use of Carbon Monoxide Detectors. A CO detector alarm should be taken seriously and you should follow the manufacturer procedures included in the package.
NEVER dismiss a Carbon Monoxide Detector Alarm for a malfunction.
ALWAYS treat an alarm as an emergency and follow manufacturer procedures.
Check our website for more industry information or for buying replacement Carbon Monoxide Detectors.
Jul 16, 2010 | Kidde Nighthawk Combo Gas/co Detector
I have a RCA gas self cleaning oven,It heats on broil but not on bake.we have noticed over the weeks the oven was getting as hot as the thermostat was set at.Now it won't heat at all
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 13, 2010 | GE Ovens
Have the oven burner gas stove emits too much carbon dioxsid what is the solution: Change the burner? Or give a pretty clean? Thanks
This is an extremely dangerous problem that should not occur. There has been a product recall for models of electrolux and kenmore's manufactured in Canada, so you should check the US Consumer products safety commission.
You should not use your oven for heat because it can also use up all the oxygen in a well insulated environment. You should never cover the bottom of the oven with foil. It blocks vents and causes Carbon monoxide to buildup.
If that is not the case, you should really have a qualified technician clean and tune the oven, because if you are right and your oven is emitting enough carbon monoxide to trigger an alarm, you can wind up dead.
Tuning can involve adjusting gas flow and checking regulators. If you still want to attempt a solution, check the top and bottom burners. Make sure the are in good visual shape and use a small pipe cleaner, paper clip or some other wire that will not break off inside the jet holes.
Clean the oven and check your manual to make sure that it does not require a vent.
Fire companies will often help out with finding the source of carbon monoxide, but they do not want people to air out or clean the offending area or appliance. Please take care, and thank you for your question.
Nov 25, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Oven smells like gas when on
If the oven is new and has never been used, it should be cured before using. There is a curing your oven page in all manuals before use. You have to wash and burn off all the chemicals used in making the thing. Are u sure it sets off the smoke alarm and not the carbon monoxide alarm. Be careful some alarms are equipped with both now a days and people cant tell the difference. Get your gas company there to check it. Carbon monoxide is undetectable to the nose and is deadly so please be very careful! If there is smoke and u have cured ur oven then there maybe some old food on the burner, remove the bottom plate and check. If there is no smoke and no food on the burner then u need to change ur ignitor. It maybe old, cracked or both. Typical repair cost on high end range is 300 - 400 for 1 ignitor. Good luck. And I urge u to see if it is Carbon Monoxide!
Sep 04, 2009 | Hotpoint RGB745 Gas Kitchen Range
Whirpool gas range - propane gas not sure oven is working right
First, the flame should be blue and without much visible yellow. You need to give the gas tube a good cleaning to get out any soot buildup and any partial obstuctions that might be causing the problem. Since you started with a yellow flame and soot, you need to get the burner tubes clean to see if you have resolved the problem after adjusting the regulator and burner valve(s).
You might need to install a different regulator to match the pressure of your gas supply source, as regulators have a specific working range of inlet (supply gas pressure) that they can operate properly at to "regulate" the supply pressure to the stove's needed pressure.
Check your manual and the installation guide to verify what the gas inlet pressure requirements are and check with your gas supplier to see what they are providing you.
To your 2nd question, yes, the gas will cycle on and off when you are using the oven, since the thermostat will call for more heat when needed and shut off the gas/flame once the temperature you set the control at, has been reached. The cycling is a result of the oven trying to maintain the desired temperature for baking.
One reason that you can smell gas when the oven is being used, is because all gas ovens have a surface vent to allow excess heat to escape from the oven compartment, however you should not be smelling raw gas (actually you're smelling the "rotten egg" additive that's put in the gas) all the time, since when the oven is turned on, a small electric ignitor is heated up VERY HOT glowing bright orange inside the oven compartment. Once it's hot enough a sensor opens the gas valve and lets gas into the burner tube to be ignited instantly by the VERY HOT ignitor. It is rare to smell raw gas with this system, but sometimes you'll get a stronger "rotten egg" smell at different times due to the gas company and their system, etc.
As to the gas smell, you should NOT be smelling gas every time the oven cycles on when baking, as a normal ongoing occurrence. During the first few uses, it is normal to smell some gas, but this should go away after a couple of uses. If it doesn't, you should look to make sure the regulator and oven controls are PROPERLY configured and set - Since you've already fiddled with these, it's probably a good idea to have someone from your gas company (or a gas appliance tech) come out and do this. Improper settings can cause some serious problems.
Hope this helps!
Jul 15, 2009 | Whirlpool Accubake SF362LXTS Kitchen Range
Robert Yick Co. RanRYC168 Gas Kitchen Range Logo
116 people viewed this question
Top Robert Yick Co. Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Robert Yick Co. Kitchen Range Expert? Answer questions, earn points and help others
