Question about Bose Audio Players & Recorders
Volume was turned up to loud,I have some 401's.has a raddling sound
  • 43 Answers
Almost surely means one or more speaker blew (voicecoil loose or cone)- rebuild time if they're worth it to you.
Posted on Aug 12, 2009
When the gas pedal is applied the car lags back and the engine makes a loud raspy noise
run the fault codes
the noise may be detonation from incorrect air /fuel ratio ( oxygen sensors failed ) or from incorrect ignition timing ( problem position sensors or ignition control module
Oct 24, 2015 | 2008 Toyota Yaris 1.5
I just bought a Coby home theater system 5.1 surround sound dvd/cd/ player model#765. I've got it all hooked up but I have one problem, when I want to listen to my tv stations through the home theater...
Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
Feb 28, 2011 | Audio Players & Recorders
Hi i have bought an onkyo ARV 401 amplifier and i
You can choose any speakers to go with your amp as long as
1) they will allow the amp to perform at its best ( impedance and power handling)
Ideally you will buy speakers which will handle the full amps output plus more, then when you turn it up LOUD, you will not break the speakers
2) you still like the sound when they are demonstrated, installed at your home.
Sound is a very individual thing, if you like it then its fine, after all you are the one listening to it most.
Hope this helps
Thanks for using FixYa
Aug 07, 2010 | Onkyo TX-SR875 Receiver
Toshiba Satellite s2450-101 Sound Driver is already installed but sound not working
Have you turned up the volume control on the right hand front edge of the laptop ? I had the same problem!!
Jun 11, 2010 | Toshiba Satellite 2450-401 Notebook
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Slight crackle on left speaker if turn volume up
the speaker is bad when you set the loud button on, you're putting more pressure on the speaker beacuse its bad it wll make that crackle sound. My advice change it.
Mar 03, 2009 | Panasonic CT-27G7 27" TV
When i turn on my amp it makes a loud beeeeeeeeeeeeeeeep.
Turn the volume down.
Check your gain.
That should solve it.
Feb 05, 2009 | Fender Frontman 65R 65W 1x12 Guitar Combo...
The volume is not loud enough on my i-pod classic
There is a volume limiter under "settings", check to be sure its turned all the way up (you actually have to click the center button to save). Also you will find "Sound Check" being turned on greatly reduces volume.
Dec 31, 2008 | Apple iPod classic MP3 Player
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Jun 14, 2008 | Sharp LC-26D43U Television
Toshiba Satellite 2450 Sound
Maybe is dumb answer, but did you try to bring the volume up by small knob on front of the laptop (right side).
May 12, 2008 | Toshiba Satellite 2450-401 Notebook
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Steve Allison
Steve Allison
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
