I want to upgrade my lenovo laptop ram memory from 1gb to 2gb by adding one more stick. i currently have ddr2 PC2-5300(333MHz) latency 5 5 5 15 2T RAM my friends advised me that BLUE SCREEN ERROR occurs sometimes while upgrading ram. please tell me the configuration of new ram which i should add?
    Scholar:
  • 56 Answers
The rule of thumb with RAM is to always buy matching pairs. So instead of buying one new stick of 1gb its a better idea to buy two of the same kind and replace the one that is currently in there.
Before you even think about doing this, head over to lenovo's website and make sure that the computer is compatible with 2gb(from the speed of the ram im assuming that it will, I don't know of many DDR2 computers that cant have 2gb.) you may also be able to get ram that is faster if it is compatible, The website will have all this info.
Posted on Jul 12, 2009
Can the LG Xnote RD405 laptop intially with 1gb RAM be upgraded to 4 gb using two 2gb RAM's ? Please help me by providing an answer clearly, Thanks in Advance.
Here is the memory specifications from LG.
Maximum Size: Each slot is 1024MB and can be expanded to 2048MB.
SO DIMM Type for Memory Expansion: DDR2 SDRAM SO-DIMM (256MB, 512MB, 1024MB)
It can take a maximum of 2 gigabytes of ram. It will take two 1 gb sticks. It uses DDR2 laptop ram. You need to check to see if you have one stick that has 1 gb or 2 sticks that have 512 mb each. That will tell you if you need to buy one or two sticks of ram at 1 gb each. You will be able to tell a difference going from one gb to two gb of ram. I think it would be worth the investment if you plan on using the computer for another year or more.
Oct 05, 2015 | LG Computers & Internet
Why does memory upgrade for biostar k8m800-mam2 motherboard cause memory error beeps?
I would verify that the memory you're using is actually working properly.
Try to boot to the new stick and see if it works.
If not, it doesn't work.
If it does, you may need to replace the original stick with the same stick that you are trying to use now.
Use this site as a guide.
http://www.crucial.com/store/listparts.aspx?model=K8M800%20Micro%20AM2&Cat=RAM
Dec 22, 2011 | Biostar K8M800 Micro AM2 Motherboard
I want to upgrade my computer specs... hope you can help me.. CPU: intel core2 duo E4600 2.4Ghz/800Mhz/2mb L2 cache/65MOnm MOBO: elite 945GCT -M2/1333 (v1.0), 1945GC/C2D/1333MHZ/DDR2 667/PCI-E memory:...
If you are a "gamer" and you have 1GB of RAM, and you have Windows XP, you probably need more RAM.
If you are a "gamer" and you have 1GB of RAM, and you have Windows Vista or Windows 7, you DEFINITELY need more RAM.
Some motherboards support "dual-channel" mode, when you have 2 or 4 _IDENTICAL_ sticks of RAM. What happens is that each byte written to the RAM is "split" into 2 halves; one half is written to the 'A' stick of RAM, while, simultaneously, the other half is written to the 'B' stick of RAM. Obviously, this takes 4 "cycles" of the RAM, rather than taking 8 "cycles", if there was only one stick of RAM. So, your RAM seems to run at "double-speed".
So, when you buy more RAM, either try very hard to "match" your current 1GB stick of RAM, or purchase a "2GB dual-channel kit", or two "2GB dual-channel kits", to upgrade to 2GB (or 4GB) of RAM.
Aug 04, 2011 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
I have Acer Aspire-5570-4765 laptop with Intel Core Duo Processor T2050 (1.60GHz, 533 MHz FSB, 2MB L2Cache) & 1 GB DDR2 (support dual channel) RAM memory. I want to upgrade RAM my memory from 1GB...
512 MB of DDR2 533 MHz system memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Yes its possible
Yes but the memory its going to run at slow speed 533Mhz
Sep 26, 2010 | Computers & Internet
Could I use MacBook Pro 1G RAM (hynix 1GB 2Rx16 PC3-8500S-7-A1) to upgrade my T400 2G RAM to 3G?
Hello thx5,
It depends on how the 2GB in your T400 is currently configured. If the 2GB in there now is just one 2GB stick of RAM then yes you can add the other 1GB stick and then you will have 3GB of RAM installed. If your 2GB is two 1GB sticks of RAM (which is more likely to be the case) then the 1GB stick you have from your Macbook Pro isn't going to help.
Note: your laptop can handle up to 8GB of RAM via two 4GB sticks.
Hope this helps, if so please leave some good feedback. Thanks.
Feb 22, 2010 | Lenovo O O - T400 Ts P8400 1G/160 Cmb Wxp...
Upgrade to 3GB in laptop?
yes you can install 1GB in one slot and 2GB in other slot. but you have to make sure that the RAMs must have the same BUS speed.
Please make rating to my answer
Sep 05, 2009 | Gigabyte GA-8PE667 Ultra Motherboard
Problem with upgrading my acer extensa 5620z memory to 4GB
Hi there.
I recommend you get another stick of SODIMM to replace what seems to be the faulty stick.
If you are using XP or Vista X86 (32bit) then the system will only recognize 2.8 - 3GB of memory, only 64bit operating systems recognize the full 4GB.
Good luck ad thanks for using FixYa!!
May 24, 2009 | Acer Extensa 5620 Notebook PC
What is the optium ram upgrade for a lenovo 3000 y410
DDR2-PC5300, and the max it will accommodate is 2GB (2 x 1GB).
Hope this helps you
Mar 17, 2009 | Lenovo 3000 Y410 Notebook
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
What kind of ram?
just look for notebook memory type ddr2, ddr2 all have the same amout of pins, you will have to remove one of the sticks of ram and replace with a 1GB or remove both and fit 2 x 1GB sticks.
seee below
http://www.ebuyer.com/store/Components/cat/Memory---Laptop
Nov 23, 2007 | Acer Aspire 5100 Notebook
Computers & Internet Logo
75 people viewed this question
Alun Cox
David Payne
David Payne
