Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Same F1 problem
I am so glad you all posted your issues because I have been going crazy and doing the same, standing in front of it and pushing cancel 1 time 3 times in a row before it corrects itself. What a pain this has been. Sound s like I am calling Whirlpool tomorrow! Thank you!!!
  • 15,935 Answers
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$^%
Posted on Sep 21, 2010
I turned on my self cleaner oven this morning and it started beeping and flashing F1. The only way I could stop it was to push the cancel button which of course turned it off
Good Morning Monica, thank you for your post!
Based off what you have described your Frigidaire range is providing you with an error code of F1 after you started a self-cleaning. The error code "F1" stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. If you continue to have issues with the F1 error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. Hopefully this information has been helpful. -Matt
Dec 06, 2015 | Frigidaire Kitchen Ranges
I need Please a solution to F1 Error Code on GE/Kenmore electric ovens Model # 911.4658815 Thanks E-mail: elylimo@gmail.com I have the same model number. 9114658811 and plugged in the stove for the...
To my understanding error code F1 would indicate a faulty control board, possibly thermistor control. The only recourse is to have this replaced.
This of course would require a fair familiarity of electrical/electronic components/circuitry and safety procedures, use of a DVM and possibly a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 13, 2008 | Kenmore 46123 Stainless Steel Electric...
The front of the panel is reading F1. What does this mean for a Kenmore Elite Stove.
HELLO,
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced GENE
Aug 27, 2011 | Kenmore Kitchen Ranges
Hlmy whirlpool is electric and we were trying to set it to clean the oven but it comes up with a f1 and then startes to beep but win't start cleaning process what does that mean?
Aug 24, 2011 | Whirlpool 30" Free Standing Electric Range...
My stove is coming up with a code F-1 what does that mean??? jo garrett
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Gene
Aug 05, 2011 | Whirlpool 30" Free Standing Electric Range...
Windows on mac time capsule
font.f1 {font: 12.0px Helvetica} font.f1 {font: 13.0px Helvetica} Thanks for asking your question with FixYa Support, I am glad to be able to assist.
I was going to map out some steps for you, but one of my articles that I have access to, is comprehensive (and effective enough)to detail steps for resolving an an issue like this, where a Windows PC cannot access a Time Machine network, this is the article for you:
Problems with connecting a PC to a Time Capsule
So try this article and let me know if it helps. If you have more questions, please feel free to reply back to this post.
font.f1 {font: 12.0px Helvetica} Regards,
-Mactechtrainer
font.f1 {font: 12.0px Times}
Apr 13, 2010 | Apple MacBook Pro Laptop Computer with...
I keep getting an F1 error code on my top load Whirlpool Cabrio HE washer. I do what the manual says to do which is to hit the Pause/cancel buttom and then start....I continue to get the F1 error code for...
There is a recall for the Cabrio F1 error code issue. I had mine fixed for free. They will have to replace the control board. You will need to call 1-800-253-1301 and tell them that your Cabrio washer is having the F1 error code and you read on the internet that Whirlpool has been making repairs. Have your model number, serial number, and purchase date ready for the person on the phone. The guy that repaired mine also replaced the washboard at the bottom for free...just ask the tech about it when he is there.
Dec 07, 2009 | Cars & Trucks
Please advise on how to reset the F1 code? The continuious beeping is driving me crazy .. Thank you
It sounds like you need a new heat sensor installed. It will run you about $175.00 +/-
Jun 01, 2009 | Kenmore Kitchen Ranges
F1 error code
The F1 error code indicates a primary control failure or pressure signal out of range. Once the pressure hose & air dome have passed testing, the control board will need replaced. Good Luck And Please Rate FixYa!
Dec 20, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Aogd2750e gas double oven
F1=Electronic range control failure
It is telling you may have a faulty control...need to replace control or EOC
Thanks
Dec 07, 2007 | Amana AOGD2750 Gas Double Oven
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Sal De
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
