Question about Directv Plus DVR DTV Receiver / 100-Hours Video Recorder
Program prompting to be deleted before it was finished
We were watching a program that we had recorded and it seemed to prompt to delete before the show was over. At first I thought that we needed to add a minute or 2 to the end of the show, but the strange thing was that when we went back to the first of it and fast forwarded to the end the amount of show that it would let us fast forward to decreased almost to nothing.
Hope this makes sense.
Tommy T.
  • 1 more comment
  • Terry720 Nov 19, 2007
    I have the same problem....sometimes it prompts when I less than half way through. My DVR is nowhere near full...and the recording is there...it just thinks it's over for some reason. I have found that if I unplug the DVR for 30 seconds...then plug it back in...it will reset and I'll be able to watch the entire recording.
  • tntblues Nov 20, 2007
    I called DirecTV and found out that this problem is a software bug and that they are in the process of sending out the fix to the boxes.
    Thanks for the tip Terry720.
  • emorganri Nov 23, 2007
    My box is doing the same thing. Thanks for the tip, Terry720 - it prevented my wife from assaulting me when she couldn't watch Grey's Anatomy. Any idea how long the software update deployment is going to take? Do you need to contact Directv to let them know?
    Sniper:
  • 59 Answers
Sounds like your DVR is running out of space try to free up some space on the DVR.Also there is a little bit of space at the end of the show after it prompts you to delete the show not much though.If you have plenty of space on the DVR simply increase the time it records by 3 minutes.that should take care of your problem.
Posted on Nov 15, 2007
Stupid magic-i program is not letting me delete it, and I want to delete it because it is blocking my webcam from showing anyone but the message, Magic-i blah blah blah something....
Hi my friend. If a program you wanted to delete still refuse to be terminated, or erased, then approach that program outside of it's territory. First, restart your computer, while your computer start to boot, pressing F8 continuesly , you'll be directed to several options that include to start your computer with command prompt. Select this option by left clicking on it with your mouse. This will appear -- c>
Example:
C:\cd program (press enter)
C:\program> (type dir/w then press enter) this is to find the stupid ( Magic I Program that we wanted to delete ) if you found it, from the C:\ command prompt, type del filename of the said program that needs to be deleted.
Example:
C:\del magic-I visual ( press enter ).
The program that you wanted to be deleted, is successfully terminated.
Hope this would help you . Have a nice day my friend.
Aug 17, 2011 | Arcsoft Magic-i Visual Effects
I can't delete a specifc program that I recorded on my Shaw PVR
Select the program, and start watching it.
Press the PAGE-UP button to "fast-forward" 5 minutes.
Do it again and again, until a window shows up: DELETE or NOT DELETE.
Select DELETE.
May 01, 2011 | Televison & Video
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
I recently downloaded a free download accelerator program that I can't manually remove either through the "Add/Remove Software" tool for the MS XP Home Version. I tried to go to the accelerator folder in...
1 goto start menu and find the run command and type CMD. if you cant get the prompt. Press Cntrl,Alt,delete for the task manager , the file , new task and type cmd , you will get the prompt
BE EXTREMELY CAREFUL AS YOU WILL KILL YOUR MACHINE
type Regedit
you are now going to delete the offending software
navigate to
computer/hkey_local_machine/software/microsoft/windows/currentversion/uninstall
Aug 17, 2010 | Computers & Internet
Icon won't delete!
Go here and download Revo Uninstaller. Run the program and look for realplayer in the list, double click the realplayer icon and choose to uninstall. Choose advanced from the options. The Real Player uninstaller will run first, follow the prompts and uninstall, when it asks you to reboot, choose no, I'll reboot later. Now Revo will tell you to click next and it will then search for all other left over files in the registry, when it is finished it will list them, select all and delete, now it will search for any other file that pertians to the program and will list them, choose delete all and hit next. Reboot the machine and all evidence of Real player or any other program you choose to delete will be gone forever.
http://download.cnet.com/1770-20_4-0.html?query=revo+uninstaller&tag=srch&searchtype=downloads&filterName=platform%3DWindows&filter=platform%3DWindows
May 11, 2010 | Dell Inspiron™ E1505 PC Notebook
Want to know how to delete IE off vista.... keeps coming up with error messages and denies me access to prog when wan to delete it.... i always run mozilla
Close all programs.
Click Start, and then click Control Panel.
Click Uninstall a Program under the Programs category
In the Tasks pane, click View installed updates.
In the list of installed updates, double-click Windows Internet Explorer 8.
Note If you are prompted for an administrator password or for confirmation, type the password, or click Continue.
Follow the instructions to uninstall Internet Explorer 8.
When the uninstall program is finished, restart your computer.
Nov 22, 2009 | Computers & Internet
Windows installer and not find status.msi
Sometimes when you delete a program you have to restart your computer for it to uninstall. Then when you reinstall using your disc that came with the printer if anything remains it will ask if you want to replace or add click replace and finish the install by the prompts from the disc and printer should work.
Sep 20, 2009 | HP Photosmart C6180 All-In-One InkJet...
Cannot uninstall Lexmark Fax Solution.
Go to www.download.com put in Revo uninstaller in the search box. select the program for download and download it. Run the program. The window will come up and show all installations on the computer. Pick the program you want to get rid of. select program and click uninstall in the header, the program will initiate the programs own self installer first, when it is done or if it fails, Revo will continue with the uninstall. Make sure to choose option (4) when prompted with the type of removal you need. if prompted to restart windows after the uninstall, ignore and continue with the Revo program. Click next when it is highlighted by Revo and select all when prompted to delete files. Revo will prompt you when it has finished, just say yes to all files to delete.
Sep 09, 2009 | Lexmark X2550 All-In-One Printer
Angelo☺
Delete the temporary Internet files
To delete the temporary Internet files, follow these steps:
1.
Start Internet Explorer.
2.
On the Tools menu, click Internet Options, and then click the General tab.
3.
Under Temporary Internet files, click Delete Cookies.
4.
Click OK when you are prompted to confirm the deletion.
5.
Click Delete Files.
6.
7.
Under History, click Clear History.
8.
Click Yes when you are prompted to delete your history of visited Web sites.
9.
Click OK.
Please note that after performing these steps, you will not be prompted the website addresses that you have gone to in past.
Mar 23, 2009 | Microsoft Windows Vista Home Premium with...
Delete old voice mail - program new voice mail
You can usually access the system voice mail setup from any extension.
Press Speaker
Dial ext 200.
When asked for security code, dial *,2,# (dial it twice if there is no code).
When main greeting begins, dial 632.
Using the soft keys under the display, press MORE, then MGR, then CHBX or, follow voice prompts if non-display phone.
Follow voice prompts. Remember, 1=Yes, 2=No.
Mar 10, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Directv Plus DVR DTV Receiver / 100-Hours Video Recorder Logo
129 people viewed this question
Top Directv Televison & Video Experts
john milligan
rundiggity
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
