Question about Royal VF1000MX Shredder
I tore up the nylon spacers that keep the paper from wrapping
Anyone know ehere I can get spacers for a VF1000MX?
    Genius:
  • 1,218 Answers
For parts give Royal a call at 1-800-524-0799;.. they should be able to help.
Posted on Aug 22, 2010
How do I know whether the blades are properly aligned?
Martin,
The manufacturer puts spacers between all of the blades to keep them at the proper alignment. If you are having issues with paper balling up in one area, it may be that one of those spacers has failed. I am not sure if you can get spare spacers or not.
May 02, 2015 | Office Equipment & Supplies
GET royal VF1000MX manual
tesfetela.blog.com/.../royal-vf1000mx-paper-shredder-owners-manual
Sep 07, 2014 | Royal VF1000MX Shredder
I need the nylon spacers on the cutter drum of my royal vf1000mx
For parts assistance contact Royal at 1-800-524-0799.
Feb 22, 2011 | Royal VF1000MX Shredder
Paper activates motor but paper will not feed (vf1000mx)
Look at the cutting teeth when the motor is running...are they turning????
If they are not turning you may have stipped teeth off a plastic gear inside...you will have to open it up to check...once you see damaged gear contact Royal at 1-800-524-0799 for parts assistance.
Jan 26, 2011 | Royal VF1000MX Shredder
Can you help me. My "trigger"
I was able to make my own by going to the local hardware store and buying 2 nylon parts and doing some careful milling/filling. The following dimensions were checked against an original EM14e trigger. These instructions may or may not work with other McCullough Chainsaws, but they worked for me!
1.) buy a nylon thumscrew with a 3.20mm (.125 in) outer diameter and 13.2mm (.5 in) THREADED length (overall length varies depending on type of flat head used for thumbscrew and overall total length will likely exceed 18mm or .75 in)
2.) a nylon spacer .25in length and .125in inner diameter that I cut in half and used a shop grinder to loosely fit onto a mounting nail. I used the shop grinder to gently mill down to 8.7mm outer diameter by slowly pressing the spacer/nail combo against the grinder wheel.
I then tested in the EM14E handle to check for fit and after several trips to the grinder for the spacer, it works great.
3.) After checking for fit I glued the thumscrew and spacer together and am now able to use the trigger. Please note if you have a working loose fit for the trigger, do what I have and simply use masking tape to keep the trigger with the chainsaw so it does not get lost.
Jan 15, 2011 | McCulloch 14" Electric Chain Saw Mcc1514
I have a Royal VF1000MX Shredder that will no longer shut off automatically.
Easiest try is to clean the "eyes" where you put the paper in....they may just be dusty/dirty,,,,if that dosnt work you may need parts...contact Royal at 1-800-524-0799 for assistance.
Nov 06, 2010 | Royal VF1000MX Shredder
Royal VF1000mx crosscut shredder jams
Give Royal a call at 1-800-524-0799 they will advise about parts replacement.
Jul 22, 2010 | Royal VF1000MX Shredder
My vf1000mx got jammed. i took off the cover and
It could just be dirty "eyes"....try cleaning them with a soft cloth they are in the middle where you put the paper in.( make sure it is unplugged first) if that dosn't fix it then it will most likely be the pcb...call Royal at 1-800-524-0799 for parts and prices.
Feb 13, 2010 | Royal VF1000MX Shredder
Royal VF1000MX Shredder Logo
76 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Ed
Ed
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
