Question about HP DeskJet 1220c InkJet Printer
1220c Ink blockage
My HP Deskjet 1220c is no longer printing yellow, i've been printing a lot of mostly brown artwork/maps out when it started coming out purple. The test page prints off every colour fine but no yellow, i've replaced the cartridge twice now and cleaned and primed 4-5 times with each cartridge, still no yellow. Is there another way to clean the heads or some kind of solvant to use ? Or will i have to open it up ...
thanks, in advance, for any help you can give.
  • 2 more comments
  • deresh Nov 17, 2007
    i have the same problem
  • Wickyup Nov 17, 2007
    My 1220C printer would not print using the yellow. I have replaced the cartridge and the printer still does not print using the yellow after cleaning and priming.
  • davitnj Nov 21, 2007
    My HP Deskjet 1220c is no longer printing yellow or any color but black or purple.that is the only colors that come out when i print a test sheet.this is from brand new cart.i have seen lots of the same problems but no answers.
    please help,,, davitnj
  • john heath Jan 05, 2012
    on reading this further the suggestions look good, will try them.
Have you guys checked that the yellow is actually coming out of the cartridge?
Its easy to check. Take cartridge out of printer. Clean bottom of cartridge where ink comes out (usually on flat metal with microscopic holes below the metal contacts) with kleenex. Place piece of clean kleenex under bottom of cartridge where ink comes out. Gently press on cartridge - see what colours you have on kleenex. If you don't have yellow, but do have cyan and or magenta, then cartridge is blocked (regardless of whether its new or not). Cleaning and priming will not work if jets are blocked with set ink.
This can be tackled!
Take one kettle, boil water!
Steam the metal jets in the kettle spout for a few minutes
Place cartridge back on clean kleenex - if still no yellow try again. If yellow, then move to clean piece of Kleenex and repeat until all three colours regularly appear on kleenex after around 30 secs.
Place cartridge back in printer
Repeat clean and prime cycle until good test pattern produced.
Posted on Jun 04, 2009
Sometimes the nozzles get clogged. If several normal cleaning cycles do not clear all the nozzles, next try removing the cartridge and setting it, nozzle-side down, on a steaming-hot damp paper towel for a few minutes, then running a cleaning cycle. If this doesn't solve the problem, as a last-ditch effort the head can be soaked in a shallow dish of alcohol for a few minutes. This cleared up a clog for me that no other method would solve, but I have heard that if soaked too long in alcohol, the head may be damaged.
Posted on Jan 25, 2008
  • 417 Answers
I believe on this printer the color cartridge is a tri color meaning that Cyan Magenta and Yellow is all one cartridge you could try removing ink cartridge and cleaning the gold contacts on the ink cartridge carriage and also on the printer cartridge. The print head is on the ink cartridge itself so changing it you would have cured it anyway.
Try the above if the same problem then the likely thing is a faulty carriage or control board.
Hope I could help
Thanks J
Posted on Jan 13, 2008
A combination of the hot steam and the rubbing alcohol dip did a great job in getting my magenta working was producing a brown that I had never was green to start with and now it's more red. Thank you!
Posted on Sep 01, 2010
  • LPOL Aug 19, 2011
    I had a clogging problem with both the B&W and COLOR cartridges. The printer had been sitting unused for about 2 years.
    Tried the HOT WATER routine on both carts. Could only get the Magenta to work on the COLOR I took the CREVICE tool on the VACUUM CLEANER and carefully sucked along the outside colors and got the BLUE and YELLOW to appear!!!!! HP Cartridges DO ****!
    Had to replace the B&W with a NEW one but I'm back up and running.
    I was about to THROW AWAY this printer.
    Thanks to the interenet...I still HAVE it.
Won't Print Color Ink
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 19, 2012 | HP PSC 1510 All-In-One InkJet Printer
BLINKING YELLOW LIGHT and the printer will not respond to a print command
it can be a damaged ink cartridge, or a damaged cartridge carriage
Aug 19, 2010 | HP DeskJet 1220c InkJet Printer
Flashing Orange light will not stop printer will not print
Feb 11, 2010 | HP DeskJet 1220c InkJet Printer
Hp deskjet 1220c It only prints in red. I thought it was that the black cartridge was empty so I changed it. But the problem persists Any ideas?
If the printer has not been used for awhile, ink may have dried on the heads. Try cleaning the heads a few times. Then see if you can print solid blocks of each color. If they show up but have lines in them the heads will need to be cleaned again until they show solid.
Nov 27, 2009 | HP DeskJet 1220c InkJet Printer
Black inky vertical linesq
try cleaning the ink tray. remove the ink and clean it put it back and try printing. put off your printer before doing to
Jul 02, 2009 | HP DeskJet 1220c InkJet Printer
The ink well is full and leaking. How do I clean it out.
There is an ink well below the home run position of the print head and cartridge assembly. If you open the lid of the printer, the print head moves to the center of the rail. You then unplug the printer and gently move the print head to the left and out of the way. If you shine a flashlight in the right hand corner or home run position, you will see the ink well. You can clean it out with a paper towel or a syringe. Obviously, the well is no longer overflowing and the drip should stop.
Apr 08, 2009 | HP DeskJet 1220c InkJet Printer
HP Deskjet 1220C cartridge recognition problem
This happens when the connections on the cartridge get old. Especially when you refill or buy non HP Cartridges, try buying brand new hp cartridges and you might be able to get a couple refill out of them before this happens again.
Feb 09, 2007 | HP DeskJet 1220c InkJet Printer
HP DeskJet 1220c InkJet Printer Logo
779 people viewed this question
Ben Johnson
