Question about Motorola Mobility MD761 Cordless Phone
Motorola MD760 dies after 5 minutes of use-- from being charged for days on base
I may have purchased a unit with a 'dud' battery, phone is new - 2 mos old and whenever used for more than 4-5 minutes of chat, it dies. Seems to not really ever charge the battery when on the base for hours/days past 25%. Is it probably just a bad battery or something more? I do not want to replace the battery if the problem is in the base or some other handset defect. thanks
  • 2 more comments
  • k8rs Nov 15, 2007
    excellent! i just pulled out the battery, wiped the contacts w rub alc. and voila! the battery looks like it is now charging. Thanks so much for the speedy response. k
  • Jomamma Dec 27, 2007
    My Motorola MD761 series cordless telephone needs a battery replacement and I have tried several sites including Motorola itself but no one seems to have replacement batteries
  • snadeau Feb 10, 2008
    I had the same problem - it's the battery. Once I replaced it, it's fine. It's so hard to believe that Motorola put out bad batteries in their phone. I have heard of this issue from several people all ready.
  • steveandcris Jul 09, 2008
    Same problem as previously described. My batteries are around 6 months old. They do not keep the phones charged. Constantly playing musical phones by placing the different phones on different handsets to keep a charge. It seems this is the second time I've replaced batteries and I'm frustrated. I've never had this much problem with any of my other cordless phones.
I have some problem in my phone
Posted on Oct 15, 2008
I think I have a problem with my base charging system, it does not keep the phones charged. Constantly playing musical phones by placing the different phones on different handsets to keep a charge. It seems this is the second time I've replaced batteries and I'm frustrated. I've never had this much problem with any of my other cordless phones.
Posted on Sep 27, 2008
  • 4,102 Answers
This is a battery prob replacing battery will solve this prob hope this solves your prob make sure the battery connectors are conected propery securely first before replacing if ok then replace batt and prob should be solved check then conectors are clean where the phone sits on base and check phone sit on base properly if it does then it is def the batt replace.
Posted on Nov 15, 2007
  • paul proctor Nov 15, 2007
    hope this solves your problem hopefully it was just loose conection and solves your prob ...................................
Brand new motorazr V3s. draing batteries. only 3 hours of use
Aug 16, 2009 | Motorola Mobility RAZR V3
All three of my Panasonic KX-TGA630S phones are extremely crackly and full of static. What do I do about this?
I already had the base unit and 2 additional handsets, but one month ago, two of the handset do not charge the battery,
I leave the phones charging for 24 hours, and certainly not reached using 5 minutes and dies
I place it in the base load, and loading sign appears, showing up not being charged as well because if I leave it 24 hours Supposed to be loaded.
Jul 02, 2009 | Panasonic KX-TGA630S Cordless Expansion...
My MOTOKRZR K1 battery/phone will not stay charged very long.
Let ur phone completely die. Don't charge it or anything when the low battery notice comes on. After it completely dies, put it on the charger only until it says charge complete. U might have to do it a few times to get ur battery performing as it should. If you charge ur battery too often, it causes ur battery to swell (weird I know) and your battery starts resisting charge. Hope this helps!! (I used to have the same phone and the same problem. I did this, and now my mom is using the phone and has an exceptional battery time)
Mar 21, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Base Unit of DECT2000 Uniden Phone system (5 Handsets) went dead
You may have a defective battery, 90 day warranty.
Mar 18, 2009 | Lands Phones
Motorola i850 will not charge completely
check may be the charger is bad if not so lose your phone, at the botton, at charging port side u see two seperate leg re-solder it.
Oct 07, 2008 | Motorola Mobility i850 Cellular Phone
Cl flashing on display
You need to reset the time after a power outage.  Press the Day/Check, Hour, and Minute buttons until the correct time is heard-- Press Day/Check until you hear the correct day announced. Then do the same with Hour, and then Minute.
Jun 01, 2008 | Motorola Mobility MD761 Cordless Phone
Dead battery won't recharge
if it still new and you've still got the warranty then you should ask for replacement of the whole unit.
seems that the problem of your phone is the unit itself, the charging circuit migth have disorders/malfuntioning.
ever tried checking for the specifications and directions for charging the unit.
i greatly suggest that if you got the warranty still, have it replaced.
good day!!!
Feb 28, 2008 | Motorola Mobility RAZR V3
Uniden handset TCX905 with base unit TRU8866-if compatible?
I just successfully registered 4 TCX905s with my TRU8865 base - it's documented in the TCX905 manual.
Be sure the handset you want to register is fully charged.
Remove the handset you want to register from its charger.
Now unplug the AC for the main base, hold down the 'find handset' key on the base and plug the AC in again, when it beeps, you can let go of that button.
Hold down the '#' on the handset you want to register, it will show 'Registering Handset...' and when it beeps, it's done - registered, you're good to go :)
Oct 11, 2007 | Uniden TCX905 Cordless Expansion Handset
New Motorola Red Razor via Sprint
i can help you with your problem ??? please message me and i can assist you from here
Aug 09, 2007 | Motorola Mobility RAZR V3
Base phone handset #1 holding charge
The base unit should not need a charge. It should be powered by the plug in adapter. It may have a battery to keep operation for a short time in a power outage. The adapter may be loose, the adapter could be broken or the plug in the phone may be broken.
Jun 19, 2007 | Uniden TRU9480 Cordless Phone
Motorola Mobility MD761 Cordless Phone Logo
419 people viewed this question
Top Motorola Mobility Lands Phones Experts
John Donghia Jr.
John Donghia Jr.
Level 1 Expert
Eric Sutherland
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
