Question about Jandy Digital Lite2 Lj325 Btu Heater, Propane
Power control board off will not change to spa or pool . Everything else seems to be in working order. The off button stays on off no matter how if is pushed or held
    Champion:
  • 246 Answers
Need new board
Posted on Aug 31, 2009
What does "Firmware Rev B 13" n on indoor control panel? Help! Robert
The firmware message is the firmware on the wall mount control. The wall control would seem to be getting power, giving you the firmware rev only. Your communication with the main board has been lost, broken wire, main board has gone bad or for some other reason can not receive and instruction from the main board. If you have a spa side control, if spa side works then board may be ok, look for bad wire. If spa side is not working disconnect and power cycle the system and try the wall mount with spa disconnected. You may only need to replace the main board. More info on your system would be needed in order to suggest the proper replacement.
Sep 04, 2014 | Pool & Spa
Service mode Compool
turn everything off then turn back on if it is still uncontrolable sounds like master pc board
Feb 27, 2014 | Pentair Compool CP3400TX Pool & Spa...
My Jandy rs control panel 7751 has gone out?
Yes! Although you the lighting is part of the circuit board, you can order a NEW Circuit Board and install it yourself! Shop around I believe we paid about $375 about a year ago.
The new circuit board should come already pre-wired with a connection plug. Disconnect power to the unit at the breaker. Gently pry off the cover to expose the old circuit board and plug. Gently wiggle the old plug off and attach the new board. I believe there are a couple of screws holding the board in place. The new board should come with instructions as well. If you are at all handy.... save yourself the install fee from the pool tech!
Mar 24, 2013 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
My Jandy rs all button says the pump is off but the pump stays on. This has happened before and it seems to reset its self or after i turn the pump breaker off it resets. What is going on?
Very odd.
I would suspect a bad relay.
Go to the outside power center located at the equipment. Press the mode button until the "Service" light is on. Now press the filter pump button. Turn it off and on several times to make sure the relay is working correctly. If not, replace the relay.
If this is not the problem then I would reset the board at the power center by pressing the recessed "Reset" button with the tip of a pencil or pen.
If this does not work, you could call Jandy and have them flash your board with the newest software.
Apr 16, 2011 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Pool heater is not working properly
So I assume you have pressed the button by pool to select the pool thermostat? If this doesn't work sounds like another mother board problem, or try powering down the unit a few minutes then restart. IF you haven't pressed the pool button, the read this: The heater comes factory set at 78° F. for the pool mode and 100° F. for the spa mode. If it's in spa mode it's trying to get to 100F. Using the up and down arrows,you can set the thermostats to a minimum temperature of 65° F., or a maximum of 104° F. If you desire to heat only one
body of water, the thermostat is capable of an off mode. As an example, if you only wish to heat the pool and not the spa simply depress and hold the spa down arrow, and the thermostat will lower its setting to 65° F. then go to an off mode. Here is a link to your manual :http://www.pentairpool.com/pdfs/MasterTempOM.pdf
Jul 07, 2010 | Pentair 460732 MasterTemp Heater 250BTU ...
I have Jandy RS4 system with 4-button poolside controls for additional spa control. Inside house control panel stays totally lit up saying ''Rev 6700'', and cannot communicate or control pool operations. ...
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Oct 07, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Digital Lite2 Lj325 Btu Heater, Propane Logo
32 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Craig Butler
Craig Butler
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
