Question about Creative Labs Zen Touch MP3 Player
Creaive zen touch
Hi my son has a creative zen touch i can get it playing but cannot view any thing on the screen he told me its when he got off the plane this happened but i have noticed a scratch or could be a crack on the screen pls help
  • done with it Nov 17, 2007
    My son zen mp3 player will play music, but the screen is blank. He has tried to reset his library and still no screen.
    President:
  • 4,402 Answers
Http://www.anythingbutipod.com/forum/showthread.php?t=18859
Posted on Dec 07, 2007
My mp3 player stays on all the time and i cant turn it off
  1. Check that the Creative Zen Touch has the most current version of the firmware driver. Firmware updates typically fix most common errors and problems encountered when using the Zen Touch. Turn on the MP3 player and select "System" in the home menu. Click "Information" then press "Settings." Select "About." Look for the internal firmware's version number listed under "Version." The most recent firmware is 2.01.00 and was released in 2006. If your software is outdated, download an update from the Creative support site: http://support.creative.com/downloads/download.aspx?nDownloadId=100120
  2. Ensure that the song files you are trying to transfer to the Zen Touch are compatible with the player. On your computer, right click the song file to view its file format. The Zen Touch can play all unprotected WMAs, WAVs and MP3s. It does not support the popular protected AAC format that is used in online stores such as Apple iTunes.
  3. Verify that the Zen Touch's internal battery is fully charged. This may cause what appears to be a blank or dead screen, as well as slow responsiveness to your touch. Insert the power adapter brick connector into the Zen Touch's power port found on its right-hand top corner. Plug the adapter into a wall outlet to begin charging. The MP3 player will be finished charging in four hours. You may use the MP3 player while it is charging, but this may slow down the charging process.
  4. Adjust the screen contrast on the Zen Touch. This may resolve any issues you have with viewing the screen in bad lighting. From the main menu, click "Settings" and choose "Contrast." Slide your finger up or down the Zen Touch's touch pad to adjust the contrast to a suitable setting.
Sep 24, 2009 | Creative Labs Zen Touch MP3 Player
My Zen Creative is stuck and will not turn off/on or play music!
If you have a warrenty "accidently" drop it on the ground and return it.
Apr 06, 2009 | Creative Labs Zen Touch MP3 Player
My Creative Zen Touch is frozen. When I hold down the "Menu" button, the screen does not change. When I connect to the computer and attempt to run Creative Mediasource Organizer, I get a message that the...
I would run the recovery console from the player itself. Make sure the Touch's power supply is plugged in (and unplugged from a PC) then to access the recovery mode of the Touch, hold down the Play/Pause button while inserting a straightened paper clip into the reset hole on your player, give it about five seconds then remove the paper clip.
Next, keep on holding the Play/Pause button until the Rescue Mode screen appears. After you see the rescue mode menu, you can release the play/pause button.
I would try a "clean up" first, as this is less intrusive and will not erase data.
Mar 27, 2009 | Creative Labs Zen Touch MP3 Player
Creaive Zen does not start. Not recognised by PC.
have you reset it? small hole on side use a paper clip.. sorry if thats obvious.. some people don't know about it..
Dec 21, 2008 | Creative Labs Zen Digital Media Player
Creative Zen Touch stuck in "recovery mode"
Hi! I think you should try this (i've already tried it and it works):
1- Unplug your Zen from your Computer.
2-Turn off your Zen (if you can't do it, press the "Reset" button)
3- BEFORE turning on your Zen, press your "Play" button and hold it while you turn on.
4-When a format menu appears, select the "Format All" option (you'll loose all your Zen data).
5-When the format menu reapears, select the "Reboot" option and listo! You have your Zen as new and should not have problem. Good luck!
Jun 30, 2008 | Creative Labs Zen MicroPhoto MP3 Player
Have you tried to load the firmware? First you'll need to download the firmware to your PC from Creative's website: Click here. After you've downloaded it, connect your Zen via USB to your PC and open the firmware icon, then click "Upgrade."
For more detailed instructions on how to troubleshoot your Zen, click here
Jun 03, 2008 | Creative Labs Zen Touch MP3 Player
Creative zen
After three months of trying and trying in many computers, following many, many procedures found all over the Internet, my Creative Nomad has accepted the firmware and has borned again.
What I did?
1. Connected the Nomad on a computer with Windows XP and Windows Media Player 9, that never has been touched by a creaive device.
It recognizes the device but can´t find any update to the drivers,
2. Updated Windows Media Player 9 to Windows Media Player 10,
3. Restart the computer
4. Connect the Nomad and the computer recognizes the device and autamtically search and found updated MPT drivers.
5. Run the firmware update program "ZenXtraP4SAudible_PCFW_LB_2_10_03 (Creative Zen Xtra PlaysForSure Firmware 2.10.03)"
6. Finally the magic button always has been disabled was enabled so start reloading firmware.
And now the Nomad is working in windows vista.
The difference between the computer where the firmware works and the others is that this has never had media player 10 or 11 and never has installed creative drivers.
Hope this can be useful to smoeone, somewhere, sometime.....
Apr 26, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative zen mp3 help please
You will need to put the Zen into recovery mode and erase the firmware, then reload the firmware. Follow these steps:
To Erase the Firmware:
1. Get a paperclip and straighten it out.
2. Hold down the Play/Pause button, and put the paperclip through the reset hole. Release the paperclip while continuing to press the Play/Pause button until you see the screen change.
3. Select "Reload Firmware."
To Load the new Firmware:
Go to www.Creative.com/support --> downloads. Click through the navigation and download the latest Zen Touch firmware. Reboot your computer, then plug in your Zen via USB cable. Double-click the firmware icon and then click upgrade.
Apr 02, 2008 | Creative Labs Zen Touch MP3 Player
Creative Zen Frozen
ARE U RUNNIG WINDOWS MEDIA PLAYER 11
Dec 17, 2007 | Creative Labs ZEN SLEEK MP3 Player
Creative Labs Zen Touch MP3 Player Logo
43 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
