Question about GE SecurityS754DAT-RST1 Motherboard
Wired alarm beeps every 30 secs. No reset code or panel box.
The wired home alarm in our house beeps every 30-60 seconds since a lightning flash. How do I reset it?
It is no longer monitored by a service company. I don't know the code and the circuitry box is locked which I'd like not to have to tear open. Ademco brand keypad if that matters. Unplugging the keypad electronics and the panel box didn't help.
We have become accustomed to the beep-beep when any of the doors are opened so I simply want to reset it. Thanks so much.
You may need a code to silence it, but you can try pressing the '*' key on the keypad.
If it is only beeping when you exit or enter through a protected door, you can remove the magnet (likely drilled down into the top of your door(s)).
If it is a low battery, you'll need to power down the system. To do that you will have to access the main control panel, pull either lead from the battery and disconnect the transformer in the house. If you have difficulty locating the transformer, go to your circuit breaker panel and shut down your circuits, one at a time, until your keypad's display is blank--track the circuit to locate the transformer.
Posted on Dec 18, 2009
    Sergeant:
  • 400 Answers
Do you have a manual for it. the manual would give you dircetions on reseting it or shutting it down completely. check the battery backup in the unit,it might need replacing.www.ademcoonline.com/Keypad%20Manuals.htm
Hope this helps
Posted on Jul 12, 2009
I have model kn-cob-lcb-ca...it does not have a digital display, it was made in 2009..a few nights ago it started beeping...4 beeps, 5 second pause then 4 beeps continuously..the manual says this is a...
send the detector back and have it replaced,
The CO sensor will not alarm to levels of CO below 30 ppm and will alarm in the following time range when exposed to the corresponding levels of CO: 70 ppm CO Concentration 60 - 240 minutes 150 ppm CO Concentration 10 - 50 minutes 400 ppm CO Concentration 4 - 15 minutes The alarm shall include a piezoelectric horn that is rated at 85 decibels at 10 feet. When the unit detects carbon monoxide, the alarm pattern will be four (4) short beeps - followed by five (5) seconds of silence - followed by four (4) short beeps. The unit shall incorporate 2 LED's. A green LED will be illuminated to indicate the alarm is operating properly when plugged into an outlet, and will flash every 10 seconds when on backup battery power. A red LED will flash to indicate that carbon monoxide has been detected until the device is reset or CO is eliminated or will flash to indicate low battery or alarm malfunction. The unit shall at a minimum meet the requirements of CAN/CSA 6.19-01. It shall also include a 10-year manufacturer's limited warranty or
Test/Reset Button - Tests the unit for proper operation. Resets the carbon monoxide alarm.
• Tamper Resist Feature - If activated, unit goes into constant alarm mode if it has been unplugged or has come loose from the outlet.
Sep 20, 2011 | Kidde Nighthawk Combo Gas/co Detector
Our hard wire smoke detector model i12060 just beeped really lound a few times and stopped, it glows green and flashes red every few minutes?
Change the 9V backup battery,with a new one.Push and hold the reset button for a minute or two for the alarm to to go off like about 30-40 sec. for the smoke detector to dectected the 9V backup battery power sourced.The green power LED light indicator will stop flashing also the beeping sounds too.
Jul 12, 2011 | Kidde 120-Volt Front Load Battery Smoke...
MY ALARM SYSTEM KEEP BEEPING UNCONTROLABLY..ADEMCO ALARM
Resetting Your Installer Code
1. The installer code (IC) is the code that allows you to access the system programming. If you forget your IC, your alarm company probably won't give it to you. This is because they use the same IC for many installed units and keep it a heavy guarded secret. If your forget your IC code, you're going to have to reset it.
First locate and disconnect the transformer. This is a cube-shaped wall outlet, usually placed around the alarm control panel. Next, shut down the alarm system's power supply. You may have to unplug a battery if you have a secondary power source connected to the alarm system. Once the alarm is powered down, you will reconnect the transformer and the battery in that order.
The rest of resetting comes on the keypad. Within 30 seconds of powering up the alarm, go to your alarm key pad press down the * and # keys simultaneously until you see "20" displayed. At the same time, you should see "Installer Code." Enter your new installer code while the "20" is still on the screen. Your installer code will be four digits. The keypad will beep to acknowledge the new installer code. After the keypad beeps, press *99 to exit the program. To check if you have reset the code successfully, enter your new installer code and press 1 (off). The keypad will beep once if you have successfully changed your installer code. If it doesn't beep, repeat the process.
Resetting Your Master Code
2. The master code is usually only used by the home owner. Other users codes can also be set up, including manager, babysitter, gardener and housekeeper codes. The home owner will use the master code to set up these other codes. The master code is also the code you will use when you come home and need to deactivate the alarm before it goes off.
To reset your master code, type in your installer code, press 8, press 02 and then punch in your new master code. Press 1 to turn off the programming. Your keypad will beep when you successfully reset your master code. You can now activate and deactivate your alarm system as you please.
Read more: Ademco Alarm Resetting Instructions ' eHow.com http://www.ehow.com/way_5752912_ademco-alarm-resetting-instructions.html#ixzz3pC2j96jl
Feb 04, 2011 | Audio Players & Recorders
Kidde nighthawk carbon monoxide detector started beeping every 30 sec.pressed reset button on front beeping continued louder, put unit ouside in fresh air for few secs beeping stopped. I opened the...
Golding93, you could very well have elevated levels of CO in your home. You should leave your house immediately and call the fire department. However, if your CO alarm is 7 years old, it could also be the alarm's end-of-life warning. Regardless, you should definitely call the fire department to have everything checked out. If you need additional assistance with your CO alarm, please call our customer service line at 1-800-880-6788. Thanks for being a Kidde customer. We appreciate your business!
Crystal Robinson
PR Coordinator
Kidde
Dec 20, 2010 | Kidde Nighthawk Combo Gas/co Detector
I've justreplced a new battery for my 2006 Audi A4. Everything is working fine, but whenever I use the key to lock my car, there is no "beep" sound and no light flashing indicating the alarm system is on....
unlock/hold key over for 30 secs ,windows will go down,then lock the car with key/hold over for 30 secs,windows will go up.then prees/hold down unlock button on remote for 30 secs,you have just reset the alarm/immobiliser.
Aug 25, 2010 | Audi Cabriolet Cars & Trucks
The wireless icon is orange. Do you know why??
Hi, 1. Unplug the power from the Modem to the Router 2. Plugin back the power into the Modem and wait 60 sec.. 3. Plugin back the power for the Router wait 60 sec.. 4. Plugin a lan cord from the router to the first wired PC 5. See if you can get on the internet 6. Login to the Router and see if the Connection to the WAN is started? 7. If not started then unplug the wired lan cable and reset the router wait 30 secs to 45 secs before unplug the power then plug the power in again. Then connect the lan cable then connect to the GUI for WEB. Make your See if it connects to the WAN. 8. Test the Network WAN -Internet and LAN - Home Network.
Take care
Jul 17, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Home security alarm keeps beeping
Most wired-in smoke detectors work off of two sources of power, electric and battery. If the beeping occurs every 30 seconds or so it most likely means you need to replace the battery in the detector. On the other hand if by beeping you mean the alarm is going off, I would first try cleaning the unit with your vacuum. If that doesn't solve the problem then the next step would be to replace the unit. Hope this helps.
Apr 08, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Thunderstom et off my alarm...
disconnected siren from main sorce, by unscrewing the correct wire from the box... then turned on breaker....
Sep 20, 2009 | X-10 25x25x10 - 5VDC
Carrier 38CKC042 Air... Problem--Alarms for 60 sec. when the fan blows
Where does the alarm come from? Is it a beep noise or a siren noise? Please let us know. The reason I ask is because this is not something I have ever ran into before. Based on the model number you provided I have determined your unit to be a typical split system A/C. I do not see even an option to install any alarms for it.
Maybe it is wired in series with another alarming device like. Maybe it is not an alarm at all but a bad bearing in the motor causing an alarm sound.
Jun 25, 2008 | Carrier 38CKC042 Air Conditioner
Westinghouse Security System
Download the manual. I can't remember if it is in the User's Manual or the Programming Manual but a sequence to reset the security code is detailed in one of them. Also, it soulds like the telephone line was wired through the system for full seizure. To defeat this, you will need to take it out of the phone lines at the outside telco box. How it is wired is that the alarm panel intercepts the telephone line first and then feeds the circuit back out to the main junction where the telco comes into the house.
Sep 07, 2007 | GE Security Simon 3 Wireless Home Security...
GE SecurityS754DAT-RST1 Motherboard Logo
673 people viewed this question
Top GE Computers & Internet Experts
micky dee
Damen Wong
Damen Wong
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
