Question about Akai PT4298HD Rear Projection Television
Akai PT4298HD displays yellow tint in lower left
I have a Akai PT4298HD that is a few years old. Recently it is starting to show a yellow tint (on a light colored background or blue haze on a dark background) in the left section of the screen where the mute is displayed on the screen when the tv is muted.
If this was a CRT I would have thought it was a burn in area on the screen. I didn't think this could happen with a rear projection tv? Any way to figure out what is causing it or how to fix it?
Thanks
  • Anonymous Mar 30, 2008
    We had the same problem with the Akai PT 4250 HD Rear Projection TV, now we barely have any color at all.
  • billydee Apr 06, 2008
    have a problem whit red tint showing on top righ corner
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
OK YOU CANT 'BURN' A REAR PROJECTION BUT THE CONVERGANCE CAN BE GOING OUT BUT I WOULD GUESS THE SIGNAL TELLING THE PROCESSOR - OR THE PROCESSOR ITS SELF- IS PROBLY GOING OUT WHICH MEANS A BOARD NEEDS REPLACING I DONT KNOW WHICH ONE I WOULD GET A PRO TO CHECK IT AND TELL YOU WHICH ONE IT IS THEN ORDER IT ONLINE AND REPLACE IT YOURSELF
Posted on Mar 24, 2008
  • 53 Answers
Uh, your tv *is* a CRT set. A rear-projection CRT set. But this isn't burn-in. It's either a dirty lens or some mold growing in the coolant. Better pray it's a dirty lens, otherwise you may as well just replace the set because the repair could be quite costly.
Lenses ought to be cleaned once a year.
Check out my solution to this person's problem:
http://www.fixya.com/support/t382484-akai_pt4298hd_rear_projection
Posted on Apr 06, 2008
Double vision w/ red & green tint
This is a comon problem
There are two large convergance chip's
the are failing .Replaceing them will
corect the problem . The chip range
in cost from 16,00-30.00 .There cheap,
so dont let the shop over charge you
for parts when and if you decide to
repair it.
Jul 03, 2009 | Akai PT4298HD Rear Projection Television
Convergence problem: Green won't adjust
You will need to replace both STK392-040 ICs you can get replacements at the following link with free instalation instructions
http://servicemanuals.vstore.ca/
Jun 03, 2008 | Akai PT4298HD Rear Projection Television
Double picture
Your convergence ICs need to be replaced. Its an easy job if you can solder. Let me know if you need any more info or a link to where you can order replacement ICs.
Apr 06, 2008 | Akai PT4298HD Rear Projection Television
Big screen tv will not turn on
Problems are in power supply or scanning circuits. Unit is in need of reair. Call in pro/tech
Nov 30, 2007 | Akai PT4298HD Rear Projection Television
Akai tv
have a good tv guy repace you convergence amp's john
Jul 31, 2007 | Akai PT4298HD Rear Projection Television
AKAI PT4298HD
If you have a good picture except for a missing color all the various circuits are working OK. Most likely you have a bad solder joint or component in the red circuit. This would also be indicated by the fact that ocassionaly the red pops in. If you have the experience remove the boards and inspect for cracked or cold solder joints. Resolder anything that looks suspicious. If this does not fix it you will have to troubleshoot the red drive circuits from the CRT back to the video IC. Another possibility is that you have a bad/intermitant red crt. I doubt that you have the equipment to check this but you can test it by moving the green crt board to the red crt. If it now works the red crt is OK. If all this fails you will need to find a reputable repair shop to look at it. If the unit is more than 5 years old it may not be worth fixing. Good luck.
Jun 02, 2007 | Akai PT4298HD Rear Projection Television
Set won't come on
FWIW... my Akai PT4298HD just quit also, same symptoms. Just 2 years old. Will continue to search for solution.
Sep 13, 2006 | Akai PT4298HD Rear Projection Television
Akai PT4298HD Rear Projection Television Logo
205 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
