Question about SanDisk Sansa Clip MP3 Player
Audio playback is garbled, distorted, and very low volume
After taking a trip in my backpack, my Sansa Clip now sounds like sh*t. Music is distorted, and podcast audio is totally garbled and inaudible. Files are ok, as I can transfer them from the Sansa to another device and they play fine.
I bought this in Dec, '08. I'll do a firmware upgrade, but seems like this unit is dead.
Any thoughts?
Thanks!
    Sergeant:
  • 449 Answers
Try using other headphones.
Posted on Jul 12, 2009
    Problem Solver:
  • 6 Answers
Battery corrosion on circuit board, changes capacitance, clean up with spirit and re-laquer
Posted on Dec 15, 2012
Recieve is garbled sounds like donald duck
Sounds like the audio driver input is being over driven causing distorted voice, regardless of the volume output. Either that or possibly the detector is incorrectly tuned to strip the audio from the carrier wave. Depending on the model both might have adjustments. My bet would be on the detector.
May 22, 2014 | Radio Communications
Samson G-Track recording volume issue
Try using a computer with a dedicated sound card, not an onboard sound chip. A condenser mike can't provide very much power on its own, and requires power from the attached receiver/amplifier.
Jun 04, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Distorted sound on the CA-3550
It could be that, or it could be that you have the wrong audio settings. Such as the quality of playback being set too low or a sound setting which is not for music.
Dec 30, 2017 | Cyber Acoustics CA-3550 Computer Speakers
Sound works for radio not for music volume is up music is playing no sound from any headphones
Did you try plugging in a different set of headphones? If other headphones work, maybe you need new headphones.
Try playing music from your Sansa through the computer, while it is tethered. If you can do this, it may mean that the audio amplifier part of the Sansa is broken-- Usually this means, 'get another Sansa.'
Also, try gently wiggling the headphone plug to the left and right, while it is plugged in. If you get music on and off, its possible that the headphone connector on your Sansa has a broken connection. This is a VERY difficult problem to fix (without breaking or melting something else inside the case) and also usually means it is time to get another MP3 player.
Nov 07, 2011 | SanDisk Sansa Clip MP3 Player
Some of my records sound distorted in playback others play fine it seems
This could be a defective cartridge or a bad belt. It all depends upon the type of distortion that is present. Poor speed control can be difficult to hear with speech but very noticable in music. With low volume sources, poor quality may not be as noticable and hide cartridge problems. Can you please update this with a description of the distortion as well as the model number?
Thanks,
Dan
Oct 05, 2010 | Technics Audio Players & Recorders
My Sansa E280 has garbled sound in playback. The
I have experienced the same problem with my sansa and taken it apart to see what the issue is. It has to do with the connection of the audio port on the board. Its not making a clean connection on mine, wiggling the cord or flexing the board in different ways made it sound right or recreated that crappy garbled sound. I still haven't found out how to permanently fix it, but taking it apart and tweaking mine has helped quite a bit getting it right.
I suggest you crack yours open and try and tweak it, or sell it.
To pop it open, if you haven't already ripped off the front cover. You'll need a very small precision Phillips or flat head(I used a flat head, can't find my Philips) On the bottom right, opposite of the headphone, there is a hole, stick the screw driver in there and remove the rubber cover, then remove the screw behind it. Now there is a locking mechanism behind the screw, you need a needle or paperclip thin enough to fit in the hole. Gab it in hard and then pry the case opfrom the bottom, leaving the top like a hing. There are 6 clips on the inside that will resist the opening, and if you have kept pressure on the paper clip, you won't have broken the anchoring clip by the bottom left. There are 5 other screws that have to be removed to get the board out to look at both sides.
Two screws on the LCD display, one above and one to the right. There are 2 screws on the board. both near the bottom,one on the right and one on the left. and the last screw is hidden in the bottom left corner of the display.
You can remove the battery and the screen if you like. If you remove the screen and reconnect, you may have to do a full shutdown(Hold down the off/on button) and start up of the unit for it to display correctly again.
When you have it all apart, have it play some of your music and prod the jack linkup. Try and figure out what makes it sound awesome and what directions make it sound like ****. Put some pressure on the board and remember what directions of flex make it sound good. Going to a FM station also works, if your headphones don't make a good connection, you can not get reception. Good luck!
Jun 11, 2009 | SanDisk Sansa E280 MP3 Player
The music is distorted when i turn the volume all the way up
The battery is your problem and needs a replacement, as denigration of the sound quality is frequently
a symptom when an amplifier is not sufficieently powered.
Replace your battery, it will no longer take a charge from the usb.
Apr 07, 2009 | SanDisk Sansa e250 MP3 Player
HP RX3715 headset/sound problem when playing video file
try turning the volume down a bit, by blasting the volume on the PDA you cause distortion. This should help out a bit.
Nov 18, 2008 | Computers & Internet
Choppy audio playback
keep the headphones in one place - although that jack may be faulty
Aug 05, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
282 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
