Boating Logo
Posted on Aug 01, 2015
How can i determine if i have a 1993 evinrude 120h V4 standars or ocean pro, what is the difference
I have a 1993 120hp V4 evinrude and i want to buy a workshop manual;, how can i determine if it is an ocean pro or standard 120hp V4
1helpful
Men's Invicta Pro Diver 0886 Watch. When was the model 0886 pro diver made please?
Question edited to add the Maker.
Invicta Master of the Oceans Pro Diver Model 0886 Men's Watch, Date First Available: 23 March 2011.
Apr 07, 2023 • The Watches
115 hp evinrude outboard motor ocean pro serial no g4045482 do you know the model number
Hi Dave I google "115 hp evinrude out board motor ocean pro serial no g4045482" and found a short Utube video so if you wanna check out the link here it is.. CHEERS-->
https://www.youtube.com/watch?v=IC2Oy8m2Sog
Mar 14, 2016 • Boating
115 evinrude losing power after 10 min at full speed
Check the tank vent. No air, no gas. Tank pick up tube may be clogged. Built in tanks usually have an anti-siphon valve that can clog.
Aug 28, 2014 • Boating
What is the fuel mixture a ocean pro 150 hp evinrude
40-1 on most 50- 1 on some year of motor?
Aug 20, 2014 • Boating
Evinrude 120hp v4 hi i have a lot of fule going into the motor it always floods and wont fire how do i know if the fule pump is stuffed
This isn't a networking problem.
But I will take a shot at it. Make sure that it is a flooding problem and not a lack of spark.
You should be able to figure both of these things out by removing a spark plug, if its flooded there will be excess of fuel in the cylinder at which point you want to check that the carb and carb float is working correctly, if its a lack of spark you may need a new rectifier.
3answers
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 • Boating
My 120hp evinrude 1993 stop when i cruise at low speed
There always that possibility and if the injectors are identical you could switch them and see if the problem moves. Then you know its that one injector. The other possiblity is spark. The wire or the coil for that plug could be weak.
Jun 24, 2009 • Boating
Top Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Boating Expert? Answer questions, earn points and help others
