Question about Acer Aspire T310 PC Desktop
Acer desktop T180 is stuck on verifying DMI pool DATA..
Acer desktop t-180 stuck on verifying DMI pool DATA...I installed 2gb RAM and now getting this error msg. -tried disconnecting power and IDE cables to HDD, DVD-removed all header cables -clear CMOS battery and jumpers(several times)-switched back to old memory twice and tried the new memory again-reloaded System Default settings 3 times-checked all cables that they were reconnected correctly-I also changed PCI/PNI to force ESDC settings to enable from disabled-tried to ALT+F10 go to into recovery - failed-tried changing boot order -same problem:-rebooted pc again and same msg.-I've tried almost everything I knew, any one knows how to correct this.-tried to update BIOS and would not update getting that its write protected. Need help pLease
    Sergeant:
  • 400 Answers
Verifying DMI( Data Migration Information/or Dynamic Migration Information) pool data refers to hard disk function. check the hard drive to see if it functioning properly.
Posted on Jul 12, 2009
Stuck at verifying dmi pool data
Try restarting in Safe Mode, press F8 at bootup and then either troubleshoot or do a system restore.
Feb 02, 2010 | Acer Aspire M1100-B1300A Refurbished AMD...
I tried to upgrade my acer t180 to windows 7 from vista basic, no i"m having dmi problems... seems like it's stuck... help please
Hello kelajo34,
There might be a Desktop Management Interface (DMI) compatibility problem with Windows 7 and the Acer T180 Vista Basic DMI. The Acer support Windows 7 eligible systems link shows all the Acer computers that are fully compatible with windows 7. (Acer T180 is NOT in this list !):
http://www.acer.com/windows7upgrade/eligible.html
Also, It might be a good idea to run the Windows 7 Upgrade Advisor before upgrading from vista basic to Windows 7 on the Acer T180. The Windows 7 Upgrade Advisor download link is at: http://www.microsoft.com/downloads/details.aspx?FamilyID=1b544e90-7659-4bd9-9e51-2497c146af15&displaylang=en
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jan 30, 2010 | Acer Aspire™ T180 PC Desktop
DMI Pool Data, Acer
You need a higher computer specification for Windows 7.
Acer Aspire T310 is design only for Windows XP Home/Professional and Windows 2000 according to Acer Support Page:
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireT310/AspireT310sp2.shtml
Jan 20, 2010 | Acer Aspire T310 PC Desktop
Wont start up grey screen with warning verifying dmi pool data on my desktop pc which is acer aspire
well varifying DMI pool data is not a warning its a process where your system hangs. install new windows or repair the old one.
Jan 07, 2010 | Acer Aspire E380 ASE380-UD500A PC Desktop
Disk read error-Verifying DMI Pool data... My
hello, Acer T180 comes with a SATA drive which are very reasonable priced these days. I think your system came with a 160GB hard drive (less than $50), you can probably get a 500GB for $50 bucks now.
here is a link to newegg for sata internal drive many of them free shiping for holiday season.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=internal+hard+drive+sata
you may come across few terms like "bare drive", "OEM", then there are regular ones. "bare drive" doens't come with wires(sata data & power connector), same with OEM- no wires, keep in mind OEM is genrally for resellers but i don't think anyone cares (:-) ).. since you are replacing the drive you have you can get by with any or these types. bare drive & OEM tend to be bit cheaper in price.
hope this helps
good Luck
regards,
Amar Sondhi
Dec 04, 2009 | Acer Aspire™ T180 PC Desktop
Acer desktop stuck on "Verifying DMI Pool Data...."
thats a os systems failer it will need to set back to new but back up your data first as this will be lost
Aug 03, 2009 | Acer Aspire T310 PC Desktop
Computer says something about verifying pool data
If it says something along the lines of verifying dmi pool data then you might have a problem with your BIOS ( the setup utility you refer to ). Here is a URL that describes a solution to this problem, it is pretty intense if you don't have at least above average computer skills - http://www.duxcw.com/faq/computer/dmi.html. Let me know if you need any further assistance with this.
Serge C.
Mar 30, 2009 | Acer Aspire T180 PC Desktop
Acer Aspire T180
check your removable media disk drives and make sure that you don't have like a jump drive or CD-Rom that the computer doesn't like. If that doesn't work, enter the BIOS setup (usually F2, F12, ESC or something like that....check the bottom of the screen.) and find the Boot Order settings & move hard drive to #1
Jan 08, 2009 | Acer Aspire™ T180 PC Desktop
It's possible you have a weak power supply not allowing it to boot. You would need a power supply tester to test this or try a known good power supply.
You could also try disconnecting all devices that consume power. I had a system where I new all the devices were fine but it would not boot until I disconnected a drive or two.
Since you reset the Bios I had one time where a system would not boot because the hard drive sata position was disabled in the bios. Hope this helps.
Sep 10, 2008 | Acer Aspire™ T180 PC Desktop
Acer descktop t-180 stuck on "verifying DMI pool DATA"
Remove and clean the memory with soft material and then fixed it back and then start the system.
If not solve then;
Remove the Hard drive and fixed back then boot the system,
If not solve then;
When booting press "F2 or Delete" to enter the bios setup.
In there find the "Load BIOS Default setting" and select and then enter.
Press "F10" to save and exit setting.
If not solve then;
REmove and replace the CMOS Battery and then do this Again
""When booting press "F2 or Delete" to enter the bios setup.
Press "F10" to save and exit setting."
If same problems Occur;
Try examine the motherboard maybe some portion on it overheat. in this case"Mother board damage" However if found nothing on the board "
do not hesitate to notify me for further instruction.
Jan 06, 2008 | Acer Aspire T310 PC Desktop
Acer Aspire T310 PC Desktop Logo
1,009 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
