Question about Sony Playstation 3 (PS3) Console
PS3 beeps then turns off/won't play anything
What does it mean when the PS3 beeps three times when you turn it on and then turns off?
    Problem Solver:
  • 5 Answers
Your Playstation 3 may be experiencing the same problems as my friends PS3. Either the problem may be a hard drive issue or the fans in your PS3 may be clogged with something. As far as Iknow this maybe the only two reasons as to why it is doing this. If those problems are not the solution, then you may have to send it into Sony to get replaced.
Posted on Jul 12, 2009
Ps3 turns on then turns off and beeps three times
Sounds like a power supply issue. Unless it is showing any other colours after the green light. Red would be ylod which means a phone call to Sony. Try a new power supply and see if that fixes it.
Dec 29, 2012 | Sony Playstation 3 (PS3) Console
System won't power up just beeps three times and nada
have you used can air to blow out the dust ports?
Jan 27, 2012 | Sony Playstation 3 (PS3) Console
When I turn my ps3 on the light next to the WIFI light glows orange and the system beeps three times and turns off. What is wrong with my system and can i fix it myself ?
Welcome to Fixya. 99.9% of the time, PS3 beeping is a heat sync problem. It means your CPU and GPU are overheated for long hours of work, poor ventilation of the console, or other reasons. The excess level of heat causes loosening the CPU and GPU. Therefore your CPU and GPU need to be re-seated.
However, before you do anything to fix PS3 three beeps, you should first try the following basic steps. Because there are chances you can easily fix this problem by them. Please Do Try.
1. Turn off the PS3 for more than twenty minutes, and then boot it up.
2. Unplug all cables, and plug them back in. Make sure they are connected correctly and firmly at both ends.
3. If that didn't work, then try to take out the hard-drive, and put it back in. Chances are this will not fix the problem but about 1% of the time it will due to the HD being connected securely.
For the most part, your PS3 still beeps 3 times after these efforts. That means you have to re-seat the CPU and GPU to fix the problem. In this case, I do recommend that you send your console to Sony repair service center, if your PS3 is still under warranty.
But for those whose console is out of warranty, I suggest they fix PS3 beeps by themselves, under the guide of professional repair manual, of course. Because if the warranty expires, one should pay $150 plus tax to Sony for repair the console, and wait 4-6 weeks for the return of PS3
Thanks
Jun 06, 2011 | Sony Playstation 3 (PS3) Console
My ps3 turned off beep 3 times and blinked red there was a disk jam i fixed that but now it wont turn on it goes green blinks blue the goes to red and beep 3 times. is it broken?
9/10 times PS3 beeping is a heat sync problem. It means your CPU and GPU are overheated for long hours of work, poor ventilation of the console, or other reasons. The excess level of heat causes loosening the CPU and GPU. Therefore your CPU and GPU need to be re-seated.
1. Turn off the PS3 for more than 30 min , and then boot it up.
But for those whose console is out of warranty, I suggest they fix PS3 beeps by themselves, under the guide of professional repair manual, of course. Because if the warranty expires, one should pay $150 plus tax to Sony for repair the console, and wait 4-6 weeks for the return of PS3.
Mar 09, 2011 | Sony Playstation 3 (PS3) Console
I turn on the playstation and then it beeps and turns off again
One common error that many PS3 players experience at some time is the beeping error that some call the "three beeps of death". What happens with this error is the PS3 will beep three times in short succession, and then suddenly shut down. Sometimes the unit will restart and play normally after about ten minutes, while for others, it will refuse to turn on at all.
If the three beeps error has happened to you, you are likely wondering if this a serious problem, needing to be sent in for repairs, or whether it is a problem that can be fixed at home. Unfortunately, there is no easy answer for this question because there are potentially multiple causes of the three beep error. If you are lucky, you may only experience this error once or on rare occasions and you may just choose to ignore the problem and deal with the rare shut downs that may occur, as unpredictable as they are.
However, if the three beep error happens repeatedly, you have a more serious issue that is going to need some proper troubleshooting and repairs.
One of the most simple fixes for the three beeps of death problem involves resetting the PS3 hard drive. In other cases, however, the problem may be the result of dirt and dust building up inside the unit, causing it to overheat. By properly cleaning your unit both internally and externally, you may be able to resolve the problem. In the most serious cases, however, you may be facing a motherboard issue that is in need of professional repair or replacement.
Mar 03, 2011 | Sony Playstation 3 (PS3) Console
My play station won´t turn on, when you push
You need to reflow your motherboard with a heat gun. You have ylod or yellow light of death. Easy fix.
Nov 21, 2010 | Sony Playstation 3 (PS3) Console
It turns it self off automatically
PS3 turn off when playing games means hardware errors and need some maintenance. Do you know, send back to game shop is too expensive and waste your time. Learn the correct repair skills and fix it by yourself is the ultimate method. Here is the repair guide for you to learn :
DIY PS3 Repair Guide
Not only such turning off problem, you can repair other red and yellow light related issues as well.After you purchased the product, you will be guided to the step-by-step videos and ebooks for you to work with.
Jul 27, 2010 | Sony Playstation 3 (PS3) Console
When i turn on my playstation3 it shows the ps3 logo when loading up but doesnt come up with the sign in menu or anything?
try restoring your ps3. turn the switch on teh back off then on. then put your finger on teh power button until you hear three beeps. ( not including the one you hear when pressin the power button.) right after the third beep let go and it will turn off. then try again. after the power beep listen for one beep then after that a double beep. it will show a menu of options. pick restore ps3 then quick format. *ALL YOUR DATA WILL BE DELETED BUT ITS THE ONLY OPTION!
Mar 04, 2010 | Sony Playstation 3 (PS3) Console
My Ps3 wont show up on the tv
Sometimes if you have that HD thing it changes the way it shows on different tvs. When that happened to mine I just held the power button until it beeped three times, it helped me maybe you'd like to try it out
Jul 06, 2009 | Sony Playstation 3 (PS3) Console
Red light blinks after beep
I look all over the net but could't find anything, until i found a site that said they
could show me how to fix any problem with my ps3. At first i was not so
sure about ordering the manual but i did, whats $5 plus i used paypal, but
long story short i fix my ps3, i recomend this site www.gameme.20fr.com
i hope this help you like it help me.
Jan 19, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
1,215 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
