Technica SA GX 650 overload, overheating, fan comes on intremittently
Pulled fan continunity ckecked out, but fan is intermittent with higher out put. Is there a 'feed back' in the fan circuit that determines if fan is operating before overheating gets critical? Will replacing the fan motor fix the problem or is it deeper in the circuit?
  • 27 Answers
SOURCE: Overheating indicator comes on straight away
You could have a bad heat relay.
Posted on Feb 26, 2008
SOURCE: I have a Technics SA-AX610 receiver that says overload .
From the manual pg 27....... "The protection circuitry has functioned because the positive and negative speaker connection wires are "shorted," speaker systems with an impedance less than the indicated rated impedance of this unit are used or under severe use, such as loud volume, excessive power and in an excessively hot environment."
Posted on Jan 17, 2009
  • 336 Answers
SOURCE: receiver says power overload, turn system off
It probably needs soldering of the voltage regulators and/or output IC.
I think that model has an access panel on the bottom (it may need to be cut out then rotated and screwed back on when done).
If it doesn't have the panel the main circuit board needs to be taken out to access them.
The regulators and output IC are mounted on the main heat sink. a little soldering and it should be good as new.
Posted on Feb 17, 2009
  • 3 Answers
SOURCE: How can I determine if airbags are operable?
If the light is not on they are fumctioning
Posted on Feb 21, 2009
SOURCE: Overload on Technics SA DA10
Cracked solder joints due to excessive heat cycling. Do not place in a shelf system. Top MUST be open for 1 ft. or better for proper convective cooling effect. Mine suffered same fate but repaired locally.
Posted on May 27, 2009
My partner's AV control stereo receiver sa / GX 650 has presented complications can not crank up the volume without alert saying overload or some s***?
turn it off and take a look at each speaker and wires something is wrong even a bad speaker may show this in your amp so before you burn it test all of them
Sep 16, 2015 | Audio Players & Recorders
Error code f61 on my panasonic sa/ht930, Kindly advise on these, Thanks.
F61 usually means the amp has detected a short or a severe microprocessor error.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a possible root cause for intermittent shutdown.
Jun 06, 2011 | Panasonic sa-ht930 Home Theater Audio...
My panasonic sa ht930 is well connected and the subwoofer is on but the stereo dont turn on
Is it refusing to turn on or incapable? Did it ever work before? If not, check your power source.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
May 17, 2011 | Panasonic sa-ht930 Home Theater Audio...
Panasonic sa-ht940 error f61
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Mar 29, 2011 | Panasonic sa-ht930 Home Theater Audio...
My Technics SA-AX540 AV Control Stereo Receiver keeps shutting off and on and displays overload. Does anyone have a fix for this problem?
Heat?
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Check for loose speaker connections as a root cause for intermittent shutdown.
Feb 21, 2011 | Technics SA-AX540 Receiver
My dvd stereo system panasonic model SA DK2 , F61 error,and immediately power down, comes on when turned on and then powers back off. please help
F61 usually means the amp has detected a short.
Feb 21, 2011 | Panasonic sa-ht800V Home Theater Audio...
I have a DVD Home Theater sound system SA HT930. The sound turns off - by itself, without any warning. Sometimes it is on start up....sometimes it is several hours in to a movie. The connections between...
But is it HOT?
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Feb 13, 2011 | Panasonic sa-ht930 Home Theater Audio...
My Tchnics Sa-Da10 shuts down on what appears to
Ahh technics. Technics always had overheating problems, trust me. Every since they started, their amps would get so hot they would hurt to touch. The reason the fan is not coming on seams to be something inside the circuit board. I'm sure that technics could fix this. If the fan works out of the receiver, then it must not be the fan. ;P
I would maybe get a computer fan, and just put it on top of the receiver and turn it on, or send it in for fixing. Also, do you have to crank the volume to get the speakers to play at your volume, and does the impeadence match the receiver. Because you may be pushing the receiver too hard.
Oct 11, 2009 | Technics SA-DA10 Receiver
Technics sa-ex300 says overload ?
it could be overheating - try aiming a fan at it for a while, see if the problem stops.
Nov 30, 2007 | Technics SA-EX300 Receiver
Technics SU-G91 OVERLOAD PROBLEM
I had the same problem. As soon as the volume reached about 24db it would go into overload. I was able to fix it by soldering all the connections on the larger power module. The one connected the the heat sink. When I took it apart there where several solder points that had come loose.
Oct 10, 2007 | Technics SA-AX540 Receiver
289 people viewed this question
 Grubhead
Grubhead
