Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool side by side refrigerator door not closing by itself. Ideas?
  • 4,070 Answers
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Posted on Jul 12, 2009
    President:
  • 1,273 Answers
Chech to be sure that the refrigerator is level and plumb. Adjust the levelers as necessary.
--W/D--
How do I get to the screws on my Whirlpool ED5GVEXVDOO I need to tighten the door handles
Your model does not have screws to the handles you can see. With the door closed, use two hands and grip the handle, with a little force pull up on the door handle to release it, the screws you seek are behind the handle on the door itself. Reverse directions to install handles.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 14, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
The big door on my side by side will no close by itself.
That is because the refrigeator is not level...
Use the adjustment features for the legs of the fridge to level it and then the door will close...
heatman101
Feb 15, 2011 | Whirlpool Refrigerators
My freezer door pops open everytime i shut my refrigerator door
Good day,
First, make sure the gasket including the bottom is clean, as well as the mating surface of the machine itself.
The machine itself should be checked for being level. Side to side, if it's a top freezer model, the hinge side cannot be lower than the other side.
As well, front to back it should be leveled but with a slight tilt to the rear to assist in closing.
If none of this helps, then the magnets in the gasket itself have gotten weak and the gasket needs replaced.
Notes: Heavier items keeped in the freezer door will help to a degree. Closing the door slower as well.
The reason this happens, is that with the main door open, then closed, a large volume of air is forced into the fresh food compartment. There are vents that are open between the freezer section and fresh food compartment. This large volume of air when closing the main door is compressed into a smaller area, causing the problem.
Feb 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool Gold Side By Side Ice Dispenser Problems
Instead of what you think the sound is, try and see what is happening when you actuate the ice lever. open freezer door, depress the door light switch, or tape it closed. now actuate the ice dispenser lever, does the flapping door open, that which opens to allow ice from bucket into your glass? Now look at the bucket itself, do you see the gears rotating? remove the bucket from the door, and repeat, do you see the auger shaft rotating?
Either of these are a complex repair, one I would not recommend DIYers to try on their own, for they require taking the door apart, and if not done right, your door may not close properly. Normally I have no problem advising a repair, but there are some i dont, this icemaker system, and compressors.
Visit www.FixMyFridge.net for refrigerator service or to ask general refrigerator questions.
Dec 11, 2009 | Whirlpool GS6NVEXSL Side by Side...
I have a whirlpool the refrigerator door will not stay close.
It shouldn't be pushing the door itself...you see the magnet that is used in the refrigerators are not repulsive.It doesn't get weaken that easily but what you can do is check if there isn't something bulging out of the fridge and pushing the door...take out all the things from inside and then try closing the door again. If door opens up again then definitely you have to look for a new gasket.
Jun 05, 2009 | Refrigerators
Hot band/divider between doors of side by side refrigerator
That is your external humidity control so that your doors do not get condensation. You are going to have to replace it. Go to repairclinic.com and they have you part
Feb 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Rfrig Whirlpool ED25PQ
The door on my ice maker does not close so frost develops on the maker itself. How do I fix this?
Apr 16, 2008 | Whirlpool ED5SHAXM Side by Side...
Whirlpool refrigerator side by side Ice control
its a defrost sensor that reads the inside temp of your freezer so it knows when to defrost itself.you need to close it so it wont allow th freezer to freez up.
Oct 12, 2007 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker on Whirlpool fridge
i know it sounds obvious but check water supply is turned on. another easy check is the inlet valve is ok
May 09, 2007 | Whirlpool GD2SHGX Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
310 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
