Question about Refrigerators
LG lrfd22850/lrfc22750 water from door dispenser lukewarm. how do i adjust water temperature to make it colder??
  • 4,070 Answers
Most have a reservoir behind the crisper in the fridge where the water sits between uses and unless there is lots of use usually does not run out of cold.
Posted on Jul 12, 2009
    President:
  • 1,136 Answers
Hi. The only way to adjust the water temp is to adjust the thermostat inside the fresh food section. Get a thermometer and make sure the temperature is around 34 degrees.
I hope this helps you.
Vic
Why would ice from the front door have an off taste but the ice in tray in the bottom freezer tastes fine?
I don't see from the literature that this model dispense ICE from the "front door." The dispenser on the left door seems only to dispense water. In your configuration the water comes through a completely closed system until it reaches your glass and should therefore not have an order or taste different from that of your cubes in the bottom Freezer.
Nov 25, 2015 | LG LRFD22850 Bottom Freezer Refrigerator...
Can you adjust the temperature on the water dispenser?
The water for the dispenser comes from a reservoir in the fresh food section behind the crisper drawers. So the only way to make the water colder is to turn down the temperature in the fresh food side of your refrigerator. The water dispenser is designed to dispense chilled water, not ice water. hope this helps.
Jan 04, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Water very slow coming out of dispenser filter only 2 months old
The water is switched on through the valve. You can have a restriction in the valve. You can also have a restriction or freezing in the filter. Most problems is the water pressure going into the back of fridge. Hope this helps,
Aug 15, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
My water dispenser does not give me water
1st make sure you got water to the frig.
defrost the frig by turning it off for 2 days with the doors open. Sometime the water freezes inside the door and the water dispenser doesnt work. the turn back on and see if you have water. every 6 months you should change the filter (it could be the problem too)
Mar 27, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
How to make the water colder in the water dispenser
The water reservoir is in the fresh food section,(right hand section), of your refrigerator behing your crispers. Turn your temperature control to a colder temperature for this section and it will make your water colder. Good Luck, Appliance Specialists
Dec 31, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
HAVE AN LG FRIDGE MODEL LRFC22750. THE LIGHT
EFFECTIVE FROM(SERIAL NO.) from 704MR***** to 801MR***** Subject Lamp Cover Melting Improvement (LG 3D Basic) / 2nd No. Loc No. Before Change After Change Note K-Code Remark Part No DESC./SPEC. Part No DESC./SPEC. 1 501A 6871JK1011A PCB Assembly,Main /
6871JK1011D PCB Assembly,Main /
WINNER1 DISPENSER ENERGY STAR '08 C 3 Change Relay SPEC. 2 503F 3111JJ1001X Case Assembly,Display /
WINNER1 BASIC BRAND ABQ33905315 Case Assembly,Display /
SOLO PARA SERVICIO, NO PARA PRODUCCION C 3 Thermoprotector addition. 3 503F ABQ33905304 Case Assembly,Display /
SOLO PARA SERVICIO, NO PARA PRODUCCION C 3 Thermoprotector addition. 4 409B 6912JK2002C Lamp,Incandescent /
60W 120VAC 0.40A 480LM - WHITE 6912JK2002E Lamp,Incandescent /
C 3 60W to 40W
Jun 12, 2009 | LG 22 Cu. Ft. French Door Refrigerator,...
Water dispenser is working very slow the water is flowin very slow.
is the s water holder frozen?
Look behind the lower left prodcue box
if not it could be the despenser valve not
opening all the way
Is the ice maker working OK?
Aug 04, 2008 | LG 22.4 cu.ft. French Door with External...
The water in the door does not dispense cold water
holding tank is in refig compartment so water is going to be as cold as refrig 38-40
Nov 24, 2007 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerators Logo
165 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
