Question about Sub-Zero 632 / S
My condensor fan is not blowing. - Sub-Zero 632 / S
    President:
  • 1,273 Answers
Check voltage to the fan motor. If voltage is OK, replace the motor.
--W/D--
Posted on Jul 12, 2009
My ac is acting funky. my ac will blow cold air as im moving. once i stop and idle for longer than 3 or 4 minutes, something will kick on and then it will start to blow hot air. as this happens, my car...
Start by checking to make sure that the a/c condensor and radiator is not full off debris. If the condensor and radiator were full of debris it will limit the air flow from the engine cooling fan which in tern will cause a high discharge pressure on the discharge on the a/c causing poor or no cooling at idle and could also cause vehicle to overheat. Check and make sure that the cooling fan as well as the condensor fan are coming on together when the a/c is turned on if equipped with 2 fans.
Sep 12, 2013 | 2004 Chevrolet Cavalier
I have a 2002 dodge ram 1500 4.7L engine. Air conditioning only blows cold air when vehicle is moving; warm air when idling... please help. Thanks!
Start by checking the condensor fan to make sure it is running while you have the ac on. If it is not blowing check the condensor fan motor fuse that is located in the totally integrated power module. If the fuse is bad it is most likely that the condensor fan motor is bad and is drawing too much amperage and will need to be replaced. Now I am assuming it has an electric condensor fan motor. Make sure that the condensor is free of debris, a dirty condensor will cause high discharge pressures that will cause poor or insufficient cooling at idle.
Aug 26, 2013 | Cars & Trucks
My AC only works when the car is in motion. It blows warm air otherwise.
Sound like maybe your a/c condensor fan is not working, should come on with a/c on, the fan sit in front or back of radiator, condensor is bolted to the front of the radiator, if its not working at stops no air blows through condensor and pressure will get high and a/c wont blow cold, while driving air is running through condersor so a/c will work fine.
Jun 30, 2010 | 2003 Lexus RX 300
2 year old Coleman Mach III tapping and not blowing cold air:
Make sure the condensor fan is blowing through the condensor on the roof. It sounds like the compressor is fighting high head pressures after running a bit.. After so many attepts, or if it suceeds in operating the load trips the circuit breaker.. Make sure the condensor is clean and air is passes through it from the fan. Just for clarifiication the condensor is the coil that gets hot and the evaporator is the coil yat create the cold air. Good Luck, and if you will, let me know how it turns out. Good Luck. Ned
Sep 19, 2009 | Dometic Rooftop RV Air Conditioner
Ac does not blow cold at idle... ac condenser fan
that seems to be the problem. If the fan does not turn on when the a/c is turned on it could be a fuse, relay, control box, or just a bad fan. Try connecting the fan directly to see if it works. Does this car have 2 fans? normally all the small cars have 2 fans one for the engine cooling and one to assist the first when the a/c is turned on. Without the fan pulling air through the a/c condensor the had pressure goes up high enough to shut off the a/c compressor. It also causes some cars to run warmer than usual when stopped. Check the a/c condensor for blockage also which doesn't have anything to do with your fan not working.
Aug 18, 2009 | Volkswagen Passat Cars & Trucks
71122 ac model starts but the fan does not blow any air .shuts off within seconds.
which fan shuts down? Outside condensor fan? Or blower inside? If its the outside condensor fan motor you probably have a bad run capacitor or a bad condensor fan motor
Jul 26, 2009 | Heating & Cooling
The AC in my 2004 Honda Accord only blows cool air when I am driving at higher speeds. When I drive slow or am stopped, it's warm hair coming out. My mechanic said the compressor isn't working properly...
it is a premature failure, That does indicate a bad/failiing compressor, or low oil charge, to low freon. If you trust the mechanic then go witht he compressor replacement and condensor. Unfortunately most oarts stores/shops require the condesor to be replaced for warranty purposes on compressor replacements.
Jul 22, 2009 | 2004 Honda Accord
Sub-Zero 632 / S Logo
155 people viewed this question
Top Sub-Zero Refrigerators Experts
Sal De
John Tripp
John Tripp
Steve Allison
Steve Allison
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
