Home
My Products
Sign In
Back to:
All Products
ViewSonic
N3251w 32 in. HDTV LCD Television
Troubleshooting
Tags
no signal
lcd tv
doesn t turn on
power tv lcd
turn signal
Viewsonic N3251 doesn't turn on right away (by 5 users)
posted by
lecole
on Nov 15, 2007
Report abuse
Upon pressing the power button the remote, the red light on the lcd tv turns green, but that's about it. I have to uplug it then press the power button again for it to turn on. What could be causing this? Weak signal?
Solve This!
I have the same problem.
X
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
4 Other Users Have The Same Problem
Comment by
Leather50
, posted on Jan 29, 2008
The
ViewSonic
N3251w I have has been giving problems for three months. Turn it on, green light, no picture or sound.
Another time it will work normally for for a time then black screen and no sound.
It may work then black screen with audio.
Turn set on, nothing than after 20 minutes a
and sound will come for a time.
I have unplug set and still get the same results.
Comment by
Guest
, posted on Dec 14, 2007
I have the same problem on several N3251W throughout our facility
Comment by
Guest
, posted on Dec 02, 2007
I've had this TV for almost two years and I just now started getting this problem last night. What's the deal here?!
Comment by
newmexico
Exact same problem, press on or remote and most of the time you have to unplug the TV and then try again.
Best Solution
posted on Feb 10, 2008
fdsadfasdf
Rank:
Apprentice
Rating:
92%, 2 votes
Solution... Call viewsonic and bitch till you get a new one (diff model). Good luck, you're going to be on hold forever.
Was this solution helpful? Show your Appreciation by rating it:
Inappropriate
Thanks for Trying
Helpful
FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on viewsonic N3251 doesn't turn on right away:
I don't want to Accept this solution
Done
Suggest a new solution for this problem
Can you Help with these Flat Panel Televisions problems?
ViewSonic N3251w 32 in. HDTV LCD Television
Scramble display
All of a sudden the display on my set (Vizio L32) is a...
Answer This...
Remote control (UBRC-120) will not work the unit.
The remote will not work, we've had the problem before and...
Answer This...
Screen Goes Black After About an Hour
I have had my tv for three years now and the tv works just...
Answer This...
Remote code
I have a viewsonic flatscreen TV and need a code in order...
Answer This...
power lock enable
i cant turn off the power lock enable 2 my 32"...
Answer This...
Let Our Experts
Solve
Your Problems
Ask!
Loading problems.
Benim
Guru
Let FixYa Experts
Solve Your Problem
Ask!
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
No
Yes
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
