Question about Sony DSR-11 DV / Mini DV VCR
DSR 11 won't eject
After loading a tape the deck won't engage. It continually tries and occasionally the function lights come on and flash once then go off again. How can I remove the tape without damaging the deck. My nearest service center is about 100 miles away so I'd like to do this myself.
3 Suggested Answers
SOURCE: DSR 11 playback problem
Pete, we are having the same problem with 2 dsr-11s.
The fix for us was the "auto repeat" switch on the back of the unit. It was "on" please turn it off.
The other idea was that the tape tension is very sensitive in the units, try exercising the tape (though exorcise might be good too) by fast-forwarding then rewind the tape start to finish. Tape that were tightly wound at the factory can cause this proble as well. Good Luck. Greg VA
Posted on May 13, 2008
SOURCE: DSR-11 stopped outputting anything
I have almost the same problem!  Did you ever figure out what happened?  Here's what I had posted yesterday:
Tech Friends -
I recently got a non-sony tape stuck in my DSR-11 (bummer) and was forced to extricate it using the "my tape got stuck in the DSR - 11" article's method of removing the top cover and highest level of circuit board:
This worked for the tape removal, however, upon replacing the circuit board and cover, the deck no longer seems to be able to do anything with video or audio.  It still communicates with FCP via its firewire connection (ie FCP is able to control FF, rewind, play functions, etc), but it seems unable to read or write video.  Also, we use it as an A - D converter box between a Beta SP deck and thecomputer (actually, this is the deck's main function here).  Even when I switch it to the correct setting (video) and check to make sure that everything is plugged in correctly (trust me, I checked, it is), I get the "there is no video here" error message.
Also, after trouble shooting the drive for a little while, I pressed the "reset" button the the rear.  I'm not sure if that matters one way or the other.  I don't think it does (that just resets the time code, right?)
The question is, would this be a case of "fried firewire jack" such as it seems so many of us DSR - 11 owners have?  Could I have done any frying myself by not having myself properly grounded when opening the shell?  Is there anyone who knows the answer?  Help!  I can't digitize my video!
Comment by eltriunfo, posted on Sep 05, 2008 The Plot Thickens...
Okay, I've checked all of the FCP settings and played with the deck more and it's only confused me more.  I can now get it to not only be controlled by the computer, but actually print audio and video to mini dv tape.  Also, I can record from my Beta SP deck to miniDV tape in the deck (connected through the "video" input on the rear of the unit).  In other words, the deck seems to function perfectly doing everything except for converting analogue to digital passively.  The way we always did it before was by keeping the input switch on the face of the unit on "video" and log and capturing in FCP with it as a noncontrolable ntsc device.  This makes me understand it less.  It means to me that it is not a broken switch, it's not a broken firewire port, everything works perfectly EXCEPT for using the unit as an A-D converter.  What the dill-yo?  If anyone in the world could offer any insight as to what could be causing this I would greatly appreciate it!
Posted on Sep 05, 2008
SOURCE: Sony DSR-80 DVcam - Cartrdge loading mechanism fouled...
The part number for the cassette assembly is A8312671F and it is around 500.00 NOT 200.00 as quoted in the article, and this price comes from the store that is reccommended in the article.
The service manual with the part numbers and prices is 9-977-696-22.
Posted on Nov 03, 2009
0 characters
1 Points
AG1980 will not load tape
Load mechanism may have frozen up and gears no longer function. Try 10D contract spray.
Sep 26, 2014 | Panasonic AG-1980 S-VHS VCR
A tape was stuck, As I tried to get it out the
I geuss the timing of the deck is off.Realignment wil be needed.
Aug 01, 2009 | Symphonic SL260A S-VHS VCR
GO.Video GV2020 Dual Deck VCR
Open the cover. Rotate the gears to eject the tape mnually.
Try again with another cassette. If problem persists, change belts.
Jul 24, 2008 | Rio Go Video GV6060 Dual Deck VCR
Tape is locked in Sharp VCR
take the case off and see if the tape is stuck around anything. if not, remove the tape deck very carefully (make sure it is unplugged first). you should be able to remove the tape fairly easy. the tape may be wrapped around something inside of the deck there, or the loading gears could be out of synch. and if it happens again you might consider getting a new vcr because to replace a new loading deck is cost prohibitive because vcr's are so cheap now.
Apr 28, 2008 | VCRs
Accordianman--Dual deck VCR not responding...
No. Sound like the Switch mode power supply is or has failed, to repair this would involve replacing capacitor and or some componets, Many repair shops these days have discontinude repairing VCR's becuse most of the time you can replace the entire unit for the cost of repairing it
Feb 24, 2008 | VCRs
Video Go Double deck VCR (Montage), Model #6060/6600/6050
Unplug the VCR, take the cover off, find the motor (probably on the right side of the mechanism) and turn its shaft with your fingers until you have run the tape back out. Now plug it back in and try it again with a scarificial tape. If it continues to fail, replace all the rubber belts in the mechanism.
Hope ya fix it!
Feb 18, 2008 | VCRs
DV tapes will not load
the "dv sensor"is actually a mechanical lever built into the cassette housing that moves the reel tables to match the reel spacing on mini or full-size DV tapes. check to see if this assembly is free to move. if it binds up, the reel tables may not move as far as they need to, and can cause problems similar to the one you're seeing. to inspect the mechanism, you need to remove the cassette housing. if you don't have a service manual, get a tech to help -- it's a delicate procedure.
Oct 11, 2007 | Panasonic AG-DV2000 Mini DV VCR
Can't insert tape into deck
Remove the cover again and move the tape carriage all the way towards the front (the carriage is not fully in the locked position). Once that is done you should be able to load a cassette again.
Sep 27, 2007 | JVC SR-V10U S-VHS VCR
High Pitched Sound
I am to believe that your static sensor on the playing head is touching the the head and it sould not. just bend it up "slightly" and the noise should disappear
Dec 14, 2006 | JVC HR-S5902U / HR-S5912U VHS/S-VHS...
Sony DSR-11 DV / Mini DV VCR Logo
4,882 people viewed this question
Top Sony VCRs Experts
Andy Fraser
Andy Fraser
Pieter Vleeshouwers
Are you a Sony VCR Expert? Answer questions, earn points and help others
