Question about Whirlpool GS5SHAXN Side by Side Refrigerator
Water leaking onto floor from bottom of whirlpool frig
  • 4,070 Answers
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Jul 12, 2009
I have water on floor under refrigerator.There is no water supply line to this frig.
If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.17 May 2013
SOLVED: Water leak in refrigerator? - Refrigerator - iFixit..or go to this link might help you as well....
water on floor under refrigerator Google Search
Oct 23, 2017 | Refrigerators
Whirlpool GX2SHBXVY05 refrigerator leaking from bottom freezer onto floor.
if it has an ice maker check the water feed hose for leaks.
also I have a freezer that ices up twice a year. poor design. have to defrost every now and then.
Jun 09, 2015 | Refrigerators
Water leaks out on the floor from Kenmore refrigerator mdl 253.7482240h
Be sure the drain line is clear from the bottom of the freezer to the drain pan.
Feb 01, 2014 | Whirlpool ET1MHKXM Top Freezer...
Why is my whirl pool frig leaking onto the floor and how can i fix it
Frost buildup inside the **** tube that leads from the evaporator coil to the bottom for defrost condensate tray is plugged. Try giving the unit a manual defrost by unplugging and leaving the doors open all night 12 hours. If the problem comes back you may have to take the cover off the evaporator coil and use a turkey baster to force warm water to flush out the tube.
Mar 12, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool frig won't fill the ice maker sounds like running but no watersomeing into it
If you hear the sound of water at the end of the harvest cycle, verify the plastic water line on the back of the refrigerator has not come out of the fill tube or water valve. Aslo verify it is not cracked and leaking. If so, water would be running onto the floor and damage to the floor could result.
Sep 11, 2009 | Refrigerators
Defrost line blocked and dumps water in front of frig once a day
Double door Maytag. Water frozen in the bottom and leaking onto the floor. Happened before and don't wish to pay the same repair person who "repaired" it 6 months ago to come out again. What can I do?
Jun 09, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water leaking into the bottom of frig. going under veggy crispers
Look for the drain trough on the bottom of the freezer and pour a mixture of baking soda and warm water down.
May 07, 2009 | Refrigerators
Whirlpool Cabrio Washer- When draining, water leaks out of hole
probably rubber hose from tub to pump broke, access from back or bottom, (cabrios are open bottom) pump in rear. there is a recent bulletin about tub ring not channeling water from dispenser completely into tub
Mar 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Evaporation tube freezes
shape the hose under frig like a J-trap and it will quit sucking air up it and it wont freeze
Nov 26, 2008 | Whirlpool GD5SHAX Side by Side...
Whirlpool GS5SHAXN Side by Side Refrigerator Logo
422 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
